REMOTE CONTROL IS NOT TURNING THE TV ON LIGHT ON THE MONITOR HAS A RAPID BLINKING BUT THE TV DOES NOT COMEON
  • 19,396 Answers
Hi.
The TV is in protect mode. It means that an internal problem is detected by the main controller board. When this happen the PSU is forced to stand by.
The problem is often a defective PSU, but the TV must be tested by a technician before replacing parts.
If the TV went in standby and does not wake up, but stays in standby with diagnostic light blinking, then the TV has on protect mode after detecting a malfunction.
When this happens higher voltages from PSU (this power supply operates at different voltages) are shut down to prevent further damage.
Before calling support ensure that you have followed the indications here:Why my TV does not start up and remains in standby.
Troubleshooting basically consists in leaving the TV unplugged to drain power completely and discharge internal circuits.
The best way to contact an authorized technician is by ringing the number listed on the owners manual. Alternatively try Fixya directory here:Fixya directory- Consumer Products Repair
Try first the troubleshooting proposed in link above. If that does not work, ring manufacturer service number.
Regarding the repair cost, this depends on the part that is defective. A common fault is the power supply, but as said this is not necessarily the problem.
For parts try Partstore or
ShopJimmy.
Regards.
Ginko.
Posted on Jan 03, 2011
Remote blinks; does not control tv
Check the infrared emission of the remote control. Check it with fresh batteries. If you wish to get more details about how to check a remote control, check this link. Pull up older posts there. Details are given.
Mar 11, 2013 | Televison & Video
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
I need a code for RCA remote RCR311STR for a Durabrand television model BH2004D.
In order for the 4 component universal remote to control your TV, you must program it with the TV code that matches your TV. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the TV.
  2. Locate the enclosed TV Code List. Find your brand of TV.
  3. Press and hold the CODE SEARCH key until the indicator light illuminates. Then release the CODE SEARCH key.
  4. Press and release the TV key. The indicator light blinks and then remains lit.
  5. Use the number keys to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your TV and press the ON•OFF key. If your TV turns off, you have found the correct code.
  7. Write the code down for future reference.
  8. If your TV doesn't turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
Program for VCR: In order for the 4 component universal remote to control your VCR, you must program it with the code that matches your VCR. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the VCR.
  2. Locate the enclosed VCR Code List. Find your brand in the VCR Codes.
  4. Press and release the VCR key. The indicator light blinks and then remains lit.
  5. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your VCR. Press the ON•OFF key. If your VCR turns off, you have found the correct code.
  8. If your VCR does not turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
May 11, 2011 | RCA RCR311B Remote Control
Samsung TV Universal Codes
  • Turn TV on. 2Press the "Code Search" button until the indicator light comes on, then release the button.3Press the "TV" button. After you press and release the TV button on the remote, the light should blink once and then stay lit.4Enter a three-digit code. The remote code for Samsung will be 004, 005, 006, 011, 012, 013, 014, 015, 017, 09, 027, 036, 037, 077, 082, 104, 105, 106, 171, 172, 196, 201 or 204. The indicator light will turn off if the code is input correctly. If the light blinks rapidly, the wrong code was put into the controller. Go back to the Step 2 and repeat.5Point the control at the television and press the "On-Off" button. If your television turns off, you have used the right code. If nothing happens, put in a different code.Read more: How to Program a Samsung Universal Remote ' eHow.com http://www.ehow.com/how_4897139_program-samsung-universal-remote.html#ixzz1LpSdxIG1
  • May 09, 2011 | Televison & Video
    What am I doing wrong?!?!?! I just bought an RCA Universal Remote. I'm following the direction to program the remote. It says to press down on the component key and enter the code afteryou press the...
    Locate the TV Code list provided with the remote
    Find your brand. It might have several numbers to choose from.
    1. Press and hold the TV key. The Indicator Light blinks, then remains lit.
    2. Use the Number keys to enter the first 3 digit code. If you enter it correctly, the TV indicator
    Light will turn off. If it doesn't, then you entered an invalid number.
    Note: If you enter an invalid code the LED will flash rapidly for 2 second. Start over at Step 1.
    3. Aim the remote at your TV and press the ON-OFF key. If you've entered the correct code the
    TV will turn off. If it doesn't, restart process at Step 1.
    If you follow these carefully and it doesn't work, you might have a defective unit. Be sure the code numbers are correct.
    Oct 27, 2010 | RCA Universal Remote Control
    Universal remote - program digital converter box and Roku?
    if you still have your remotes you can program the buttons for each funtion.
    1. Hold down P until the red light blinks
    twice.
    2. Press 9 7 5. The red light blinks twice.
    3. Press the device key that corresponds with
    the desired device's remote (TV, CBL/SAT,
    DVD, VCR or AUD).
    4. Press the desired learning key. The red light blinks rapidly.
    5. Place the device's remote control head-to-head
    (about 2 inches apart) with the
    11
    Gamer Remote.
    6. On the device's remote control, hold down the key to be learned until the red light on the Gamer Remote blinks twice. If the red light does not blink twice, repeat Steps 1- 5.
    7. To lock in learned functions on the Gamer Remote, hold down P until the red light blinks twice.
    8. To test a learned function, press the learned key on the Gamer Remote and use the function as usual.
    Jan 14, 2010 | Radio Shack (15-2147) Remote Control
    TV REMOTE CONTROL NOT WORKING
    1. Turn your TV on.
    2. Press tv on your Sky remote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
    4. Press tv on your Sky remote control again.
    5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
    6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
    If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
    At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
    8. Press tv on your Sky remote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
    10. Key in the number of the channel on your TV that you use for watching satellite TV.
    11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
    Oct 17, 2008 | Philips HDD065 MP3 Player
    Apex Digital GB4308 remote
    Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
    Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
    Televison & Video Logo
    23 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
