Question about Hotpoint Aquarius WMA52 Front Load Washer
The washing machine is a wma52 and has a 1 year old new pump on it last year. it will not drain the water away but is not making any strange noises like before. is it the filter?
  • 2,509 Answers
Make sure rinse hold is not selected It is very likely that there is a blockage, you should SWITCH OFF and check that the hose is clear (care have some towels ready to mop up water). Do you have access to the drain hose? Take it out of the standing pipe or whatever it is connected to and lower into a bucket, is there any water coming out as it's trying to drain? If water pours out then the blockage is not in the hose, but the pump could be broken or the blockage could be in the plumbing it was connected to. The majority of cases are caused by the pump (or filter but I don't think it has a removable filter) being blocked. If the pump is not making any noise it could have something stuck in it or simply be broken.
Here is the user manual: http://laundry.manualsonline.com/regman/exit/ct?url=aHR0cDovL2RsLm93bmVyaXEubmV0LzEvMTc0YmZmYTItZjA4OC00ZTg0LWFhNjktMGE5YTRhZmQwZTc0LnBkZg,,&target=productDoc&idDeviceType=3003&idMfg=672&idProduct=361237
Posted on Jan 03, 2011
  • Hotpoint Master
  • 1,525 Answers
Hello, check the filter if ok then check the drain hose that connects from the pump make sure it's not kinked does it connect to plastic pipe and straight out through the wall make sure this not blocked.if it connect under the sink make sure your sink not is blocked if the pump has failed check the wiring to the pump hope it helps
regards
shaun
My machine will not drain after rinse cycle. Making strange noise. What do I do, please?
I'd suggest the drain pump is either blocked or not working for another reason.
Feb 10, 2015 | Washing Machines
Hoover 1200
Remove all excess water by draining to a bowl. Clear filter and drain pump blade and all will be fine.
Jul 15, 2012 | Hoover Washing Machines
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Machine not draining
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM5145/2 Front Load Washer
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Strange noise upon initial start-up
try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Jun 01, 2009 | Whirlpool LHW0050PQ Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
LG TROMM washing machine can't open door
You need to unplug the machine, and drain the water from the drain hose, accessing the drain pump.
Once you access the drain pump also remove all obstructions in drain lines, this often fix teh problem.
If you do not have done anything similar before, then it is better to call the technician.
Jan 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Motor makes loud rattling noise during rinse cycle
could be the coupler and the only way to truely check it is to take the pump, then the motor off. But it seems strange to me that you say it works fine. Is it spinning? usually when the coupler breaks it sounds horrible and usually will not spin but it will drain.I would check the coupler again.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint Aquarius WMA52 Front Load Washer Logo
70 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
