Question about Denon DRA-697CI
My denon dra-697ci receiver volume plays fine for a couple of minutes then the volume cuts off how can i fix it easy
  • Denon Master
  • 6,771 Answers
You have bad connections on your circuit boards, if you are handy with a solder iron then you will need to touch up the solder joints.
Posted on Jan 03, 2011
Dra-697ci thee is power to unit however no lights on display or around standby button checked both fuses they are okay any suggestions would be greatly appeciated
Are there any indicators blinking? If so, and even if there are no indicators, the probable cause is DC Offset(meaning a damaged amplifier). You will need a professional Audio tech for this type of damage. If you'd like further assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Jan 14, 2014 | Denon DRA-697CI
I have a denon dra-697ci power is plugged in but face does not have any lights nor does the power switch have any both fuses are okay any sugestions would be greatly appreciated
Most likely, you Denon has a condition known as DC Offset(meaning a damaged amplifier which requires a major repair) The other issue, may be a microprocessor IC, a computer within you Denon) that has had some issue, causing it to not power up. Try a Factory Reset first. The procedure is found in you owners manual under, Reset, Factory Reset, or Rest to original setting, as it came from the factory..If you need further assistance, please contact me at my my website at audioserviceclinic.com. Thank you.
PS3 Audio and Display Issues
Check the HDMI cable type- try multiple cables.
Oct 18, 2013 | Denon DRA-697CI
Can dra 37 be used as a pre-amp without connecting speakers
If you mean a sa control center for source selection, volume and tone control, yes, but NOT for a turntable (no PHONO).
Controlled audio goes emerges from the pre-out. Page 9.
http://www.retrevo.com/support/Denon-DRA-37-Receivers-manual/id/696dj086/t/2/
But you could still use its own speaker terminals if your exxternal amp has is remote or has its own volume control to match it up with other speakers.
Sep 05, 2011 | Denon DRA-37
Denon DRA 455 cuts out after a couple of minutes on any volume, wired correctly has it finally died or can it be fixed?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 07, 2011 | Denon DRA-455 Receiver
Denon dra 397 shuts done if I turn on both zone a & b. Have a 100 watt volume control on each pair of speakers. Works fine with only zone a or zone b on, but not both.
Let's understand this - you have an external volume control wired in series with each front speaker set?
Can you elaborate on their electrical characteristics?
http://www.retrevo.com/support/Denon-DRA-397-Receivers-manual/id/696dj087/t/2/
Page 24.
A + B 8 - 16 ohms
Jan 22, 2011 | Denon DRA-397
Dennon DRA 697ci with bose 901 speakers.....just moved to new house....hooked up stereo and can only get minimal output
I assume it used to work. You need to ensure the connections to and from the active equalizer are all proper. I would think you have it in the Pre-Main loop.
It sounds to me like you have an in/out reversal at the EQ or a dead Tape Monitor selected.
Or MUTING is selected on the DRA.
Dec 25, 2010 | Denon DRA-697CI
The volume on the left channel on my old (20+ yrs) Denon stereo receiver is too low intermittently, usually until it warms up from use, and sometimes after. Ideas?
Problems of this nature are often caused by electrolytic coupling capacitors. If you have access to an audio signal generator. Inject signal at volume control and compare left and right output levels. This will isolate fault to pre amp stage or power output stage. freezer can be very usefull in isolating this type of fault.
Feb 27, 2010 | Denon DRA-455 Receiver
Denon DRA 397 Won't Turn On
me too did you ever get it fixed
Dec 16, 2008 | Denon DRA-397
Denon DRA 395 volume creeps to max by itself
I also had this problem with my Denon DRA 395. I fixed it by replacing the batteries in my remote! Apparently when the remote batteries are nearly gone, but not 100%, they are capable of prompting the remote to unilaterally increase the volume at irregular intervals. It was kind of spooky!
Oct 01, 2007 | Audio Players & Recorders
Denon DRA-697CI Logo
227 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
