Question about HP LaserJet 3050 All-In-One Printer
My printer is jammed how do i open it hp 3050
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
Read the manual
Posted on Mar 04, 2015
4 Suggested Answers
  • 102 Answers
SOURCE: multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Posted on Jul 04, 2009
SOURCE: HP Laserjet 3050 No paper pickup
it could be of dust particals on printer's plastic kind of thing looks like xray paper just clean this and restart your printer - it works
Posted on Nov 18, 2009
pineworks
  • 4041 Answers
SOURCE: doc feeder jam (hp 3050)
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 17, 2010
Cartige area jam in hp laserjet m1522nf
Open the cover and remove the toner cartridge, check to see if there is any paper or bits of paper along the path (check on the back as well).
Dec 30, 2013 | HP LaserJet 3050 All-In-One Printer
Feeder jam hp 3050 laser Print
Fisrt check if there damage or strange in the path of paper or , remove paper then with Wet clean pack up roller ,if you alcohol spary ,use it to clean rubber , hope help you
Mohamed Hejazi
Afaqnama - LIbya
ipg@hplibya.com
Feb 19, 2013 | HP LaserJet 3050 All-In-One Printer
HP 3050 door open message
Your printer HP 3050 has problem of door open the printer had 3 or 5 senser in which one senser is not working so the message comes on screen
Jan 01, 2011 | HP LaserJet 3050 All-In-One Printer
HP 3050 paper feed jamming problem
HP paper feed error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 04, 2010 | HP LaserJet 3050 All-In-One Printer
ADF on model 3050 is jammed, how do you unjam it?
Automatic Document Feeder (ADF) jams are usually caused by a worn separation pad. This small parts keeps the printer from pulling more than one page thru the feeder. When the pad gets worn the pages slip and the printer gets several pages at one time and this is where the jam comes from. The parts you need is HP RM1-0890 it is available on the web at places such as here: http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_52&products_id=139
I hope this helps, if so please rate our solution.
BuddyMc
Jun 09, 2010 | HP LaserJet 3050 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Paper jam HP Laserjet 3050z
Open tray 1 and pull any visible jammed media out of the all-in-one.
If no media is visible, open the print-cartridge door, remove the print cartridge, and rotate the
upper media guide. Carefully pull the media up and out of the all-in-one.
Close tray 1.
Aug 26, 2008 | HP LaserJet 3050 All-In-One Printer
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
My printer now spits out the paper all over the place and jams up all the time. Did not happen when I first got my 3050 a few months ago.
Jun 06, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
54 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
