Question about Sharp UX B700 Plain Paper Inkjet Fax
Printer problem my printer keeps telling me check cartridge. i've checked it and it still dosent work. My printer dosent even let me print out the help page. What can be wrong with my fax. were the cartridge goes inside the fax that part dosent move at all.
  • jsilvester Aug 25, 2008
    i have tryed two new cartiges and it still says change cartage
  • mlangan1972 Sep 10, 2008
    Same - I replaced cartridge/unplugged machineovernight in effort to reset/ still get printer error message and it won't even print test page.
I'm trying to just use it as a printer.... Says CHECK PAPER or READY TO SEND Wont Print
Posted on Sep 17, 2008
Epson Workforce 600 not recognizing black toner
I had the same problem and was told by the store that sold it to me that some printer manufacturers do this on purpose as they make their most money on the ink they sell not the printer. I got rid of mine and purchased an ink jet black only printer as this is all I need anyway. A lot cheaper to use.
Jun 12, 2017 | Office Equipment & Supplies
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
Hi, i'm getting error message 1203 on the printer and we've lost the user's manual. Can you tell me what this is?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Article on refilling Dell ink cartridges
Rick
Sep 10, 2011 | Dell 926 All-In-One InkJet Printer
My printer keeps telling me to check cartridges.
Check this HP FAQ for your printer:
Print Cartridge Errors
Also follow the links at the en of the page form more troubleshooting advice.
Sep 09, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Ink Cartridges are full but keeps telling me they are not to then
as a printer mechanic .i had got many customers coming at my work shop with this problem .and it gets soved by replacing the cartridge with new cartridge.as you said cartridges are full still it says change cartridges.but if the circuit of the cartridge is got faulty it will not print let it be full.so clean the brown colour metal circuit on the cartridge with a dry tissue.if its due to dust got stuck up on the circuit it will print otherwise the cartridge has to be changed in this case.
Feb 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Won't print
Try the following steps:
Check for and remove any grayscale settings. Use the following steps to check this setting.
  1. In the program, click File and then click Print . The Print dialog box opens.
  2. Select the correct product and then click Properties . The Properties dialog box opens.
  3. Click the Color tab.
  4. Check the Print in Grayscale setting. If necessary, unselect the setting.
  5. Click OK to save the settings.
If this doesnot work:
    1. Open the Printer Toolbox .
    2. Open HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
    Now Click the Estimated Ink Levels tab. This will tell u that the cartridge might be running out of ink even if the graphic shows that there is ink remaining in the cartridge.Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • If this doesnot work:
  • If the Print in grayscale option is not the problem and the print cartridges are not low on ink, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
    1. Load the input tray with unused plain white paper.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    3. Release both buttons. The self-test page prints.
    This will definitely work for u.
    Thank u.
    May 27, 2008 | HP DeskJet F380 All-In-One Printer
    No Print Cartridge
    if this message is present with both old n new catridge,u better check the top cover not properly seated or there is a lever on the right side which is being pulled up by the top cover ,pls check ,it is being properly pulled up by top cover,after pulling up the top cover properly,put the toner catridge ,see its properly seated (horizontally parellen)n check the printer,
    do revert
    thnx
    Jan 26, 2008 | HP LaserJet 3055 All-In-One Printer
    HP 1350V all-in-one
    Hi, You need to get a new ink cartridge. It is really not recommended to refill ink cartridges but if you do then it is advisable not to exceed 3 times because it could damage the printer head. If the new inks still gives error, then your printer head may need to be checked to see if it needs replacing. Good luck!
    May 25, 2007 | HP PSC 1350v All-In-One InkJet Printer
    Sharp UX B700 Plain Paper Inkjet Fax Logo
    94 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    jasbo
    jasbo
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
