Question about Stoves 720EF Electric Double Oven
I have a stoves double oven the fan oven heats up but not hot enough could it be the stat and if so how do i replace it.
  • 250 Answers
It could be the stat. First check that the sender unit located at the top rear of the oven above the fan cover is bright and clean and not covered with dirt and grease. Use a paint on oven cleaner to clean it in situ as it is quite easily damaged. Lakeland do one. If that doesn't work, then the whole oven unit will have to come out of the kitchen carcass and the the top and rear oven covers removed for access. Try espares for the part. If you want to check the oven temperature before you start, Lakeland do an oven temperature thermometer for about £5 which I have found is accurate.
Posted on Jan 07, 2011
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Aug 02, 2011 | Stoves 720EF Electric Double Oven
Main oven not heating up , fan running ,temp light on but no heat
I suspect that the oven element has failed, to check this, remove cover at rear of oven compartment, there you will see the round oven element, it should feel hot after turning oven on to heat, if it is cold, replace it.
Feb 28, 2011 | Stoves 720EF Electric Double Oven
Hi there i have a stoves newhome double oven the bottom oven has suddenly stopped getting hot the fan and light are still working but we have no heat.we have tried changing the thermostat but that has not...
If the fan is working o/k, then I would suggest that bthe oven fan elementt has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Dec 28, 2010 | Stoves Ovens
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
Jan 16, 2010 | GE Ovens
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
Creda reflection double oven and grill
if fan inside oven starts but no heat, then the probability is that the element is open circuit and needs replacing
Jun 29, 2008 | Ovens
Neff model U1461
your convection element has blown by one online and replace it yourself
May 25, 2008 | Neff U1461 Double circotherm plus Electric...
Stoves 720EF Electric Double Oven Logo
100 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
