Question about Ovens
After setting time for cooking, oven does not heat
  • atcherley1 Jan 03, 2011
    Thank you, Daniel, for your speedy reply.
  • 4,323 Answers
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
Posted on Jan 03, 2011
My brand new Hoover electric oven FEC66.01 S is not heating fast & it takes a long time to cook anything on the electric burners. Help me.
Make sure you have the right voltage . Check your neutral wire for good contact . Then check the oven settings. 10_11_2013_8_30_04_am.png
Jul 18, 2013 | Ovens
Tip
I have not checked the heating element with a ohm meter yet but the heating...
If you are having problems with your electric oven heating up too slowly, not being able to maintain temperature set point, or wild variations in temperature, then you probably have a bad baking element in your oven.
The bake element is the bottom element in your oven. The life span of these elements can vary depending on the usage of your oven and the quality of the element. Anything electric has an unpredictable lifespan. Elements made on the same assembly line can vary greatly in how long they last. But when the element burns out it will need to be replaced to have your oven work properly.
The thing the fools many people is that many ovens will use the broil element to preheat the oven and then switch to using the baking element only. When this happens the oven will no longer heat and will cool down. The unit may sense this and activate the broil element again which will cause wild swings in temperature and also can cause food to burn on the top self or not bake properly.
If you can see the elements, watch them and see if they both get red hot when initially warming the oven. If only the top, broil element gets hot then you have a burned out element or a bad contacts where the element plugs into. Usually lifting the element and pulling out on it will release the element. If the contacts are discolored or pitted then they could be causing your problems. By using an ohm meter you can check the resistance of the element. If you get no continuity through the element it is no good. Bad elements will often have blisters, bubbles, or even burn in two.
If the element contacts are bad, make sure the you replace both the element and the receptacle that the element plugs into. Replacing only the element will only temporarily solve your problem.
http://www.fixya.com/support/r4319770-maintenance_range_stove_or_oven
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r4501853-oven_cord_wiring_oven_3_wire_or_4_wire
on Mar 29, 2011 | Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
I have recently purchased a Neff double oven UI722 and am experienncing difficulty with the heat control. Most things I cook seem to burn either at the sides or bottom or both . Can you help in any way...
It can be difficult to 'acclimatise' to a new oven particularly if it is a fan oven as cooking times are usually shorter.
Temperature distribution is also different so if you are following your normal cooking temp and time you may need to adjust these so as not to overcook.
Try a few set recipes from the hand book using the set times and temperatures to see if that makes any difference.
Good Luck
Dec 19, 2010 | Neff Ovens
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Gets hot too quickly food cooks too quickly
    no oven heats to what the dial says, all are to hot or to cold. try reducing the cooking temperature by 50 *, so instead of cooking a roast at 350, set at 300. i have never seen a stove that is heating to the temperature of the setting.
    Jul 05, 2009 | Zanussi ZBF260 Electric Single Oven
    Instruction manual
    HI SIR
    When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
    Multifunction Oven Function Selections
    2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
    3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
    4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
    5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
    6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
    7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
    8. Fan-assisted Baking or Patisserie Setting
     - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
    top
    Advanced Oven Features
    Cavity Cooling
    The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
    Triple Reflective Door Glazing
    Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
    Wipe Clean Enamel (Extra Optional)
    Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
    Drop Down Grill Element (Extra Optional)
    The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
    top
    The Electronic Timer
    Normal Baking
    Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
    To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
    Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
    top
    Fan Forced Baking
    Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
    Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
    Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
    Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
    Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
    top
    Grilling
    Function 5 & 6: During grilling the door may remain closed or completely open.
    This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
    Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
    Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
    Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
    Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
    As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
    Sep 11, 2008 | Ovens
    OVEN TURNS ON BUT WONT HEAT UP.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
    Ovens Logo
    64 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
