Question about Microsoft Windows XP Professional
When I try to shut down my computer it will just continuously restart. When I disabled the automatically restart thing, it gave methe BSOD with error code 0x0000007e (0xc0000005, 0xba5e25d, 0xba4dbc38, 0xba4db934) Fs_Rec.sys- adress BASE251d base at BASE2000 Datestamp 3b7d8361. I'm what you would call technologically retarded.I have no idea how to fix it. Please help!
  • Microsoft Master
  • 508 Answers
Your problem can be caused by a bad memory.Or if you upgraded your memory recently make sure your motherboard can handle the memory you installed last.Some computers require memory to be installed in pairs two 256s or two 512s, try to remove one of them.
Posted on Jan 03, 2011
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Hp invent repeating startup error
If it is showing a blue scree of death (BSOD) and shuts downbefore you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 keyrepeatedly until you see SAFE MODE. Scroll down below Safe Mode and youwill see an option to Disable Automatic Restart. Select it and rebootyour machine. Next time it boots up you will be able to read the errormessage. You'll probably need a system disc or repair disc to fix theblue screen error message.
Mar 26, 2012 | HP xw4600 Workstation - 1 x Intel Core 2...
KDL52EX700 shuts down and restarts
If it is showing a blue scree of death (BSOD) and shuts down before you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down below Safe Mode and you will see an option to Disable Automatic Restart. Select it and reboot your machine. Next time it boots up you will be able to read the error message. You'll probably need a system disc or repair disc to fix the blue screen error message.
Mar 26, 2012 | Computers & Internet
Automatic restart my laptop.Windows vista
If you are able to boot the computer in safe mode, you can disable the Automatic Restart from the Control Panel.
Open Control Panel.
Click on the System and Maintenance link.
If you're viewing the Classic View of Control Panel, you won't see this link.
Click on the System link.
In the task pane on the left, click the Advanced system settings link.
Locate the Start up and Recovery area and click on the Settings button.
In the Start up and Recovery window, locate and uncheck the check box next to Automatically restart.
Click OK in the Start up and Recovery window.
Click OK in the System Properties window.
You can now close the System window.
From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
If you're unable to fully start Windows Vista due to a Blue Screen of Death error, you won't be able to disable the automatic restart on system failure option as described in the steps above.
Try the steps below:
Just before the Windows Vista splash screen shown above appears, or just before your PC automatically restarts, press the F8 key to enter Advanced Boot Options.
You should now see the Advanced Boot Options screen.
Using the arrow keys on your keyboard, highlight Disable automatic restart on system failure and press the Enter key.
After disabling the automatic restart on system failure option, Windows Vista might continue to load. Whether or not it does depends on what kind of Blue Screen of Death or other problem Windows Vista is experiencing.
Since you disabled the automatic restart on system failure, Windows Vista will no longer force a restart when it encounters a Blue Screen of Death.
Now that you have the STOP Code associated with the Blue Screen of Death, you can troubleshoot the problem:
The following is the list of BSOD error codes with troubleshooting, you can find the troubleshooting steps using the error codes in the MS website also..
http://pcsupport.about.com/od/findbyerrormessage/tp/stop_error_list.htm
Hope this helped you. Please do rate me.
Thanks!!!!
Dec 21, 2010 | Computers & Internet
A blue screen appears when i turn on my computer.... sayin "a problem has been detected and windows has beed shut down to prevent damage to your computer."
A blue screen or Blue Screen Of Death, BSOD, is generally caused by a corrupt driver or a bad software installation.
First, you need to determine the STOP code that is on that screen.
  • Start in safe mode, press F8 repeatably as the computer starts up,
  • check Disable automatic restart on system failure (This prevents Windows from automatically restarting if an error causes Windows to fail.)
OK, now the BSOD will stay there so you can determine what caused your problem. Report back the stop code and any information about a driver that caused the problem so we can be of further help.
If this answers your question, I would appreciate 4 thumbs
Sep 15, 2010 | Computers & Internet
Blue screen error: IRQL not less or equal
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Mar 13, 2010 | Microsoft Windows XP Home Edition
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    Every time i try to turn on my computer it shows bsod for a split sec and the restarts again? can u help?
    You can configure Windows to not automatically restart when a bsod occurs. In the Control Panel, go to System and then select the Advanced tab. Then click Settings under Startup and Recovery. Clear the Automatically restart checkbox.
    Now when the bsod happens, it will stay until you power down the computer. You can read the STOP error of the bsod and any potential file name. Now you can search for the exact error and solution.
    This article on troubleshooting blue screen errors might help you further.
    Jul 29, 2009 | Computers & Internet
    Dell Dimension 5100 shuts down then reboots automatically, This is one bugger of a problem. Had continual problem with unit shutting down no rhyme or reason, cant see BSOD message off too fast. Did change...
    Try rebooting to Safe Mode. Right-click on My Computer and hit Properties. In the System Properties window, click on Advanced. Then click on Startup/Recovery Settings. Uncheck Automatic Restart. Then post the BSOD Stop Code here.
    Nov 18, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
    Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
    Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
    If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
    1.
    Right-click My Computer, and then click Properties.
    2.
    Click the Advanced tab.
    3.
    Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
    4.
    Clear the Automatically restart check box, and click OK the necessary number of times.
    5.
    Restart your computer for the settings to take effect.
    Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
    Nov 04, 2008 | Computers & Internet
    Microsoft Windows XP Professional Logo
    80 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
