Power supply and heat okay but drum not turning
  • 2,509 Answers
Usually it is the belt or the motor. TURN OFF POWER open and see if the belt is intact. Model? Make? Clues? Error messages?
Posted on Jan 03, 2011
Alienware x51 v2 will not power up
check all fans are running and its not over heating.
May 25, 2014 | Computers & Internet
Dryer will not start but light comes on, heats drum okay. The dryer heats, the light goes off when the door closes, checked the drum and the belt is okay. When the start button is pushed nothing happens.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 30, 2010 | KitchenAid KEYS750LQ Electric Dryer
NO HEAT FRON DRYER , DRUM OK
either your heating element,hi-limit switch,cycling heat switch, thermistor,control panel, or you don't have 240 volts supplying the dryer,120volts will still let the drum turn or the timer count-down, its the way there wired
Nov 01, 2009 | Dryers
Eo4 eject and reinjert tape, unit in safeguard mode .it´s a jvc mini dv model no. gr-d225e digital video camera. I can see thought the camera come on okay.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Sep 08, 2009 | Video Cameras
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
Drum turns but no heat
If it's electric sounds like you have lost line 2 for power supply. Line one will make it run and tumble and line 2 is only for heat. Make sure you're getting 240 volts to the dryer.
Jun 30, 2009 | Maytag MED6400TQ Dryer
Dryer does not heat
TRY CHANGING THE HEATING ELEMENT
May 03, 2009 | Dryers
Whirlpool dryer won't heat
Okay...first of all, what led you to this point where you are troubleshooting the heating circuit? Does the drum still turn? The first thing to do before assuming you have a bad component if check the power at the receptacle. You should read 220-240 VAC. If you are missing one leg of your 220 service, you will get similiar symptoms as the dryer heating circuits require 220 service, while the motor that turns the drum only uses 110-120 VAC. The result: A dryer that the drum spins, but won't heat. This has caused many people to believe they had a bad appliance, only to find out that the problem was the electrical supply.
The heating element should read between 9 and 13 ohms. Make sure you aren't measuring anything to ground or you will get improper readings. Also, make sure you are actually measuring on a resistance scale and not using a continuity check. Disconnect the wires from the terminals of the heating element before measuring. Measure at the terminals of the element. If you still get 0 ohms, you may have an element that is grounded to the chassis. If this is the case, I would recommend replacing.
Some dryers also have a heat relay. The manufacturer places a wiring diagram inside the operator console. Sometimes the heat relay will go bad and will not energize the heating circuits. This can also cause a no heat problem. The realy (if equipped) will be located inside the operator console, and is a simple item to replace.
I hope you find some of this helpful. Let me know what your dryer symptoms are.
Sep 12, 2008 | Dryers
Model LEQ2152ES0
check the drive belt is on the pulleys
Jul 08, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
