FixYa.com
Tags:
Acer Aspire 3000  PC Notebook
Acer 3000 battery (by 2 users)
posted by ceezer on Jul 09, 2008
hey, I have an acer aspire 3000 with your same issue (computer won't run unless battery is disconnected), however it works perfectly fine in safe mode. I did install XP and it worked perfectly fine, but when I did the SP3 update that's when it would freeze upon normal boot (the clock worked normally, but the keyboard and touchpad froze). I suspect this is and isuse with one of the updates, which kinda sucks. Let me know if the new battery solves the problem, otherwise I think it's some kind of a software conflict causing a hardware failure.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 25, 2008
Same problem with battery on in Aspire 3005WLMi with XP home SP3 - any way to install some driver to fix the issue?
Solution #1
posted on Jul 19, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had the same problem 8mos. I don't use the batter. I have a new problem, when I try to connect to Net via wi fi, it crashes...time for a new laptop....It was cheap and lasted for over 2yrs.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 18, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I had the same issue with a friends 3000.  Rebuilt with XP SP2 and updates as of July 17, 2008.  Works fine in Safe but once battery is installed touchpad locks up.  She is just leaving the battery out.
Can you Help with these PC Laptops problems?
PC Laptops
vista windows
when I log onto my laptop, a... Answer This...
PC Laptops
camera assistant software
I can't find camera assistant... Answer This...
Acer Aspire 3000 (AS3004WLCI) PC Notebook
PLEASE HELP ME
i have no sound on my acer... Answer This...
PC Laptops
LG LS50 PC Notebook Power...
Hi, my problem is with the... Answer This...
acer wifi card
can I have a phone number of a... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
