Question about RCA HD52W58 52" TV
RCA R52WH74 convergence problem
This is weird, I can view some movies perfectly, but other movies like "10,000 BC had a convergence problem. Tried auto and manual, but still get double lettering etc. Put on "Sex and Death," beautiful. What is going on?
  • elpaso_dude Jul 09, 2008
    I tried adjusting the convergence for this particular movie, but the convergence never adjusted to it. You are right though, the wide screen for the movie was even wider for the normal wide screen of the TV. The other movie filled out to all edges perfectly and the picture was good... So you are saying that I have to change the aspect ratio for this particular movie (on the TV) and it will set right?
    Thanks for the response though. I think these TV's need help in the area of convergence.
  • Anonymous Aug 10, 2008
    can not get the colored crosses to converge
    picture is terrible
    have tried with remote control and buttons on tv
    thanks
  • 70 Answers
Your television is a multi system television and has different aspect ratios. if you are viewing normal 16:9, and 4.3 then you have enter the service mode and adjust the convergence for every aspect ratio. also the convergence between progressive and standart is different. if you are lucky enough to have magic focus or auto convergence all you need to do is hit this button in every mode that the problem is occuring on.
Posted on Jul 09, 2008
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model R52Wh74 RCA and we have blue color all on the screen
Have you tried to do auto convergence and see if that helps? If not try manual convergence adjustment
Jun 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA R52WH74 52'' Projection and the color on the set is in red,green,and yellow. Tried adjusting, however, does not help. Any clue?
sounds like a convergence issue. IS the picture also pulled in from top and bottom. In customer setup menu do you have the convergence option. I suggest you read "the fl231 fuse problem" in the tips and tricks section of this website
Jun 05, 2009 | RCA Televison & Video
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the convergance amp?
Accros the top of the chassi.conv power supply is to the left
Apr 23, 2009 | RCA HD52W58 52" TV
I need help: Snowy picture/Bad convergence problem/Turns itself o
Have you tried the TV in more than one outlet to make sure it is not an outlet power issue?
Apr 11, 2009 | RCA R52WH76 Television
fl231 is solderd in and will have to be replaced along with DL231 and CL230
Apr 07, 2009 | RCA Televison & Video
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
R52WH74 WONT CONVERGE
first question is the picture also bowed in on top and bottom. if so you may have the common fl231 fuse problem if you do consult the fl231 problem under the tips and tricks section. if you dont then you defently hav a convergence issue. the thing to look for is under setup do you have the autoconvegence option if you dont then you have that problem.
Jan 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W58 52" TV Logo
153 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
