Question about Microwave Ovens
I have just had delivery of a dual fuel Indesit cooker. How do I remove the cover of the electrical terminals. On the cover there is a picture of a screwdriver pointing to the two bottom corners of the same cover but no screws just two blind slots on the bottom of the cover. Once the cover is off there will be no more problems. Thanks if you can Doug.
    Brigadier General:
  • 8,909 Answers
The cover sounds as if it has snap fit lugs to hold it on and the two slots are for a screwdriver to prize the top off.
Posted on Jan 03, 2011
Changing the lamp in microwave of GE model pt970srss
If it is at all like a plain microwave oven, you will have to remove the screw for the cover to access the insides and likely will find that the light is not a simple screw-in bulb but a sealed package with a spare of spade terminals on top. It may be held in by one or more screws.
It is possible that this could be like a new conventional oven where you have to remove a light cover inside the cavity to access the bulb and change it
May 13, 2014 | GE Profile PT970 30" Built-In Double...
Operating interior light of bosch quantum speed microwave oven
Replacing the bulb is not really that tricky, and they only cost a few quid, so definitely worth doing:
1. unplug and take the cover off,
2. remove the two screws at the sides of the control panel, and move the panel out the way,
3. remove the metal plate covering the bulb area (5 screws),
4. squeeze and detach the springy fold of metal holding the bulb,
5. pull off the the bulb's electrical connections
6. unscrew and unhook the bulb, and replace!
My bulb was a 240V 25W T170 with right angled terminals.
Aug 18, 2013 | Microwave Ovens
Indesit cooker clicking
Hello, the clicking sound is as a result of bulged capacitor. One or more capacitors on the power supply board inside the unit is bulged, that's why you are hearing the clicking sound. Have the power supply board check and the cause of the porblem will be revealed. Good luck.
Dec 29, 2011 | KitchenAid Microwave Ovens
I need to wire my electric cooker upto an electric sockey
If the cooker didn't come from the factory with a plug on the cable, you cannot safely do that.
Consult a qualified electrician.
Jan 23, 2011 | Microwave Ovens
I am unable to access the blown bulb from inside the cooker compartment. Do I remove the back cover from the oven to facilitate the bulb replacement ?
Remove either the back cover, but most likely the top.side covers. Make sure that the power plug is disconnected, your are working with a lethal appliance!
Jan 18, 2011 | Microwave Ovens
I have a creda europa solar plus double oven and want to replace it with a BOSCH HBM56B550B will the power supply I have be enough for the Bosch?
What you must do is calculate the total power required by the Bosch cooker. Convert it into Amperes and copper cable is roughly 10 Amperes per 1.50mm cable. What size cable feeds you cooker at present? Or
Is the maximum power calculated for the old cooker the same or more than the new cooker. If it is and the old cooker was installed by a qualified electrician observing local electricity codes, no problem get it fitted, if not consult a qualified electrician.
Jan 01, 2011 | Microwave Ovens
Please email instructions for elba dual fuel cooker, thanks
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 21, 2010 | Microwave Ovens
Something smelt hot then it stoped working and it wont turn on
could be dust or bugs on the electrical terminals or boards in side take outer cover off and blow our should be phillip screws around the outside to remove make sure unit is unplugged
Nov 19, 2010 | GE JVM2070 Microwave Oven
Good morning We are about to fit a rangemaster classic hood 120cm approx. to suit our Elan 110 dual fuel cooker with a gas hob. What is the corrrect distance we should leave between the hob and...
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Nov 03, 2010 | Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
