Do you know where could I get the circuit diagram of this power supply? I have many years fixing TV sets but this is really wreckd Thanks in advance. Mario
    Brigadier General:
  • 8,909 Answers
What set is it from, there is no mention of a model number or make.
What is the problem with it?
Thanks.
Posted on Jan 03, 2011
I want to know how to check ballistic voltage on a dip tv
    How to test TV Powersupply Review - YouTube
    ? 5:19
    https://www.youtube.com/watch?v=TELvc0thP34
    Nov 8, 2011 - Uploaded by Tampatec
    powersupply Common problems & solutions to fix TV power issues, How to test troubleshoot Sony power supply repair help ...PLS I WANNA THE MANUAL FOR SONY CRT TV MANUAL FOR MODEL .... I can do is check everything out on they power board. an you tell me how to do this on everything?Missing: ballistic ‎dip
    Notes on the Troubleshooting and Repair of Television Sets
    www.repairfaq.org/sam/tvfaq.htm
    Nov 17, 2009 - Low voltage power supply fundamentals; Standby power supplies; Typical TV ..... For more info or if you want to buy one, see DLP TV Showcase." ... is a good chance of repair without access to specialized test equipment and parts. ...... If the bulb lights at full brightness, you know there is still a major fault.
    Dell W5001C 50" plasma fix - Instructables
    www.instructables.com/id/Dell-W5001C-50quot-plasma-fix/
    InstructablesMy buddy's Dell 50" W5001C plasma television conked out one day so I set out trying to fix it. ... Make sure the first thing you do is measure the voltage on the Va test point... I know this is a really old post, but i found a dell 4201c on the trash the other .... I can't or don't want to pay to fix, I may be off to Best Buy for a new TV.Missing: ballistic
    Amazon.com: NEW BALLISTIC PERFORMANCE LITHIUM ...
    www.amazon.com/BALLISTIC.../B005KLOYHE
    Amazon.com, Inc.
    Rating: 3.3 - ‎23 reviews
    NEW BALLISTIC PERFORMANCE LITHIUM EVO2 12V 12 CELL ..... false codes to your bike during the starting process since its voltage will dip in and out.
    ELI5:How do digital devices know how much energy is left in ...
    https://www.reddit.com/.../eli5how_do_digital_devices_know_ho...
    RedditNov 16, 2013 - Want to join? .... ExplainedELI5:How do digital devices know how much energy is left in their batteries? ... A digital device will take this voltage and will look up how much ..... I had a cable tv installer who put little caps on the end of a few .....Electronics such as lithium drill batteries and other battery items test ...
    Do modern TV's (LCD/LED) really need a Voltage Stabilizer ...
    https://www.quora.com/Do-modern-TVs-LCD-LED-really-need-a-V... QuoraThis causes temporary power dips to other electronics, like the LED TV, which in turn affects the TV's processes. In fact, one of the reasons why many LED TVs ...Missing: ballistic
    The First Lunar Landing
    https://www.hq.nasa.gov/alsj/a11/a11.landing.html
    NASAJan 5, 2016 - However, it is often desirable for the engineers to know what the residuals were before .... [Armstrong - "We did landmark checking to check our position over the ground, and that ..... [That is, Houston wants Eagle to use the aft omni-directional antenna.] ... I'm getting a little fluctuation in the AC voltage now.
    Power Rectifiers
    www.myerspowerproducts.com/index.php?option=com...id...
    Medium Voltage AC Power Solutions ... Low Voltage Switchgear ... Low VoltageSwitchboards, Panelboards & Meter Boards · Low Voltage ... Cable Television.
    Searches related to I want to know how to check ballistic voltage on a dip tv
    tv power supply repair
    tv power supply diagram
    tv power supply symptoms
    power supply for sony bravia tv
    tv power supply repair kits
    tv power supply repair cost
    sony tv power supply board
    sony tv power supply problems
    1 2 3 4 5 6 7 8 9 10 Next
Feb 09, 2016 | Televison & Video
Emerson green flashing light
This will require some answers from you:
If set 1-2 years old were you having to turn set on several times to get it to come on?
This is common and directs where the problem may be.
All sets have a shutdown circuit which were first designed in sets over 40 years ago---they monitor voltages in power supply and if things change beyond tolerance the latch or shutdown circuit shuts the set off.
This was designed so a chain reaction could not happen and destroy multiple parts.
The green light could also be the set trying to boot up after a power loss or being unplugged---all sets have a standby supply that runs 7/24 if the set is plugged in---problems happen here with filter capacitors failing from heat (1-2 years) and if you have that I can tell you what to look at.
To answer you main questions:
Begin with voltage tests inside of the power board (follow ac cord to it) and see if they are present (most have the voltages marked on the board but not all).
The metal frame inside is chassis ground---the power supply has two different grounds--earth and hot in the power supply--means some voltages DC are measured from one ground and others from the other.
If LCD as model indicates it could also be any board anyplace in the set but you have to start with power supply.
Let me know as much as you can---been fixing sets for over 30 years and the technology has changed a lot but certain basic approaches remain the same.
Mar 19, 2012 | Emerson LC320EM9 32 in. LCD HDTV
Samsung 40" lcd tv with power supply fault?
you need to replace the 10v blown capacitors with 16 volt or higher go to utube and type in samsung power supply fix and you can do this yourself for about 30 bucks
May 30, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
When I turn my tv on it comes on for a sec then screen goes off and the standby blinks red. What is wrong with my tv?
Lets figure out the problem before providing a complete solution here.
The stnadby light should blink in a repeated pattern of a fixed count of blinks with a short pause inbetween. Please post that count. It will indicate the circuit that has the problem. Once we know that we can provide a solution.
Thanks,
Dan
May 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV will not turn on Panasonic TH42PZ85U
Power Supply Board is dead.Replaced it with a refurbish power supply board.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Mar 28, 2010 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Power supply problem with Phillips 46pp8621/79
Your chassis is the DPTV 325 you can get the factory training manual for your set emailed to you at the following link. It cost 12.99 but comes with unlimited tech support if you need it. The manual is listed as DTV300 series training manual its has the trouble shooting proceedures and diagrams that you would need. heres the link.
http://servicemanuals.vstore.ca/
May 11, 2008 | Televison & Video
TV turns off/on by itself
thats why you got this TV for free I'm afraid. Your problem will cost more then the set is worth to have it repaired. Unless you understand how the differant circuits work, and know how to read a schematic, follow the circuit flow, and use a multimeter, this will not be an easy fix for you to do. There are components in the power supply that need to be replaced. Good Luck
Jul 21, 2007 | Philips Magnavox 27MS343S 27" TV
Tv powers on and goes off after about 3 seconds
This set has a problem in the horizontal sweep circuit or in the main power supply. Most likely a failed component, and the set shut down to protect the rest of the circuit. If you know how to read a schematic diagram and how the circuits operate, then you will need a good multimeter and an ESR type capacitor checker to find out the short in this set. Sometimes the CRTs(Picture Tubes) will leak the coolent fluid out and onto the printed circuit boards. Also sometimes the convergence IC's can cause this problem, but if that is the case the small little pico fuses will pop also. If you have had no solid state or printed circuit repair experience, play it safe and call in a trained tech. Good Luck
Mar 17, 2007 | Mitsubishi WS-55907 55" Rear Projection...
20 inch T.V.
You have a bad vertical output IC, or the sweep power supply that drives the IC is bad. Your going to need the service schematic diagram and the know how to fix solid state electronics.
Sep 01, 2006 | Durabrand DWT1905 TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
