Question about Candy F248P Electric Single Oven
How do I set the timer following a power cut on TCP21x and is there a diagram available to describe the timer controls as I dont have a manual roger@cottage -gardens.net
  • Candy Master
  • 19,396 Answers
Hi.
Without the full model number (as written in service tag) I cannot locate the manual.
Please check if oven is in manual mode and try the following. Try also pressing down main knob.
If you have a timer with a dial on it, please ensure that the function indicator has a hand in it for manual control and make sure the time of day hands are locked with the time to start hand. I think this model is fully digital.
If your control timer is digital then the control indicator should be set to manual as shown.
If that does not fix the problem, then please provide full model number or enter model number here.
Posted on Jan 03, 2011
Main oven not working following a power cut. Timer flashing AUTO and clock control buttons not working
The auto function will cut off the power to your oven try switching the oven to manual control to reset the control.
Apr 26, 2015 | Ovens
Smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
I have a Candy TCP21x oven and the bottom fan oven has stopped working as well as the digital display, the top oven still works. Any ideas?
problem with the board.. is it under warranty? Have tech get replacement if it is. May have to pay labor.
Nov 19, 2014 | Candy Ovens
I have an old Simpson fabulous 300 bench top stove in our beach house. We are unable to get the oven to work at full power. We have fiddled with the timer dials in the past and always get it going but it...
First of all, thank you very much Lindsay for choosing FIXYA today for your online technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Unfortunately a User's Manual for that particular SIMPSON appliance is no longer available.
However the problem is most likely that your TIMER has been set to AUTO which will prevent the oven from functioning. The timer needs to be set in the MANUAL mode.
Here are a few links to some other online resources which describe the various procedures for setting the clock and switching the timer mode which may help with your particular problem:
http://reviews.ebay.com.au/Things-to-check-if-your-electric-oven-won-apos-t-heat-up?ugid=10000000001213735
http://john.daltons.info/appliances/Simpson%202001%20Instructions.html
http://product.electrolux.com.au/Public/File/14880 (SELECT OPEN FILE)
http://www.simpson.co.nz/FAQs (SELECT ELECTRIC COOKING FOR APPLIANCE TYPE)
http://www.ehow.com/how_7382695_set-timer-simpson-wall-oven.html
Just use your mouse to click on the links, which are the underlined and blue highlighted sections of text just above. This will open a new web browser page automatically for you and allow you to view the information at the websites indicated.
I truly apologize Lindsay for not being able to provide you with the exact support documentation that you requested, but unfortunately on occasion the desired material is simply not available online.
I still hope this was at least somewhat helpful to you.
Good luck and take care.
Joe.
Jan 15, 2012 | Stoves Ovens
I have a stove built in oven and had a power cut and it keep flashing 8888 and wont work
Hi.
After power cuts most ovens need resetting, for this reason 00:00 is flashing. The operation is described in the specific model's user manual. Most ovens reset either pressing or holding down for few seconds a Clear or On button, or holding down the main control knob.
Aug 06, 2011 | Ovens
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
I replaced the flash timer on my oven and the power still does not come on what else could it be???
Is the electronic timer in the manual mode?
Is the element faulty?
Poor connection at the oven element terminals?
No voltage output from the oven thermostat control?
The oven thermal cut-out switch has operated and cut all power to oven?
Feb 08, 2011 | Frigidaire Ovens
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Cant get oven to work after power cut,creda gainsborough 48185
Hold down minute minder + cook period buttons. The + or - buttons will then set time.
Mar 24, 2009 | Ovens
Candy F248P Electric Single Oven Logo
206 people viewed this question
Top Candy Ovens Experts
ashburton
ray gallant
Gaark
Are you a Candy Oven Expert? Answer questions, earn points and help others
