Question about Compaq EVO D510 CMT P4 2.5/20GB/256MB (268899999) PC Desktop
Cr2032 memory battery flat in 5days from new!
    Brigadier General:
  • 8,909 Answers
Very unusual unless the battery was purchased from a 99p store.
Try another one?
Posted on Jan 03, 2011
How do you put a battery in zoostorm pc
LOOK FOR A SILVER BUTTON BATTERY. BE CAREFUL AND POP IT OUT. DO NOT FORCE IT. ONCE YOU GOT THE BATTERY OUT GO GET A NEW BATTERY WITH THE SAME NUMBERS LIKE FOR EXAMPLE IF IT SAY CR2032 YOU THE REPLACE IT WITH A CR2032.
Oct 11, 2014 | Computers & Internet
Www ehow com
Cmos battery is usually a 3 V button battery, there are variety of different brands so you need to open and check it.
eBay: ACER ASPIRE 7741G 334G50 MS2309 CMOS BATTERY - 476
http://www.ebay.com.au/itm/ACER-ASPIRE-7741G-334G50-MS2309-CMOS-BATTERY-476-/161408573087?pt=AU_Components&hash=item2594b35e9f&_uhb=1
2035, 2032 can be bought from any super market or hardware store. Need to open the PC, locate the battery, which is normally clipped to the mother board. Use a small screw driver and lift out. If battery is soldered to the mother board then need to access under the board and de-solder carefully without damaging the tracks.
2032: CR2032 CR 2032 5004LC 3V 3 Volt button cell lithium battery for CMOS
http://www.ebay.com.au/itm/CR2032-CR-2032-5004LC-3V-3-Volt-button-cell-lithium-battery-for-CMOS-/271586313364?pt=AU_Electronics_Batteries_Chargers&hash=item3f3bce4494&_uhb=1
solder types: SONY CR2032 3V SOLDER TAB Pin battery with soldering tag for CMOS Bios PLC new
http://www.ebay.com.au/itm/SONY-CR2032-3V-SOLDER-TAB-Pin-battery-with-soldering-tag-for-CMOS-Bios-PLC-new-/271570170168?pt=US_Single_Use_Batteries&hash=item3f3ad7f138&_uhb=1
Aug 30, 2014 | Acer Aspire Z5771-UR31P - All-in-one - 1 x...
When i turn on the computer it tells me that i need to press F2 continue to boot into the os system
You may have a flat BIOS battery and the BIOS cannot keep the Date & Time setting.
Install a new BIOS battery, it maybe a coin size battery type CR2032 3 volt lithuim battery the go into the BIOS and set the Date & Time etc.
Jun 07, 2012 | Compaq Presario S6500NX (DQ181A#ABA) PC...
Cmos battery error failure
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
Jan 26, 2012 | Intel DG31PR Motherboard
Does any batteries support any sort of motherboards
Any brand of CMOS battery will work on any motherboards as long as it has the same size. Make sure to bring your CMOS battery when buying a new to make sure the size is the same.
Your feedback is greatly appreciated. Thank you for using FIXYA.
May 04, 2011 | Compaq (203966-001) Motherboard
My PC always gets this "checksum error" ..."date
Are you inserting the batteries with the totally flat side up and button side down?
And did you remember to put the clear cmos jumper back where it was, because if not, not only may you have damaged the unit, but that is the only explanation I can see for draining the battery like that.
The PC should never be powered on while the cmos jumper is in the clear position.
Mar 15, 2011 | Microsoft Computers & Internet
How to change battery on asrock k7s8x motherboard
A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 03, 2011 | Asrock K7S8X-R3 Motherboard
Where do I get a replaement for asus li-on battery pack BA-DI-LMAI, philippines?
GoodLuck!
CreativeTECH
Dec 22, 2010 | ASUS Computers & Internet
What is the correct battery replacement for a Matsonic MS9158E?
GoodLuck!
CreativeTECH
Dec 07, 2010 | Matsonic MS9158E+ Motherboard
Always start up with cmos checksum error, cpu ratio has been change
A BIOS checksum error is most likely caused by a flat BIOS battery.
Replace the battery with a new one (it is usually a coin size battery - type CR2032) and then boot up and go to the BIOS configuration and set the Date & Time setting etc.
Jun 30, 2010 | MSI K8MM-V Motherboard
Computers & Internet Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
