Question about Cameras
I have a Samsung 880 X Digital Zoom 8mm Camcorder and would like manual on how to hook up to TV to watch Tapes
  • 41 Answers
SOURCE: i need a user manual
The answer is simple. Go to jvc.com - you can download it from there.
Posted on Apr 28, 2008
Bubbabear64
  • 2794 Answers
SOURCE: 8mm analogue camcorder tape playback at double speed
If you ran it through that many 8mm players, I'm going to say that the tape has something wrong with it.
You can see visually if there is anything wrong with the tape by releasing the cover by moving the tape and visually inspect the tape for anything that could be frayed. Usually you can see it on the bottom of the tape.
Sometimes the takeup can be messed up in the tape too. Once you release the tape cover, you can turn the white wheels to see if there is any slack in them.
Good luck on that.
Posted on Jun 11, 2008
SOURCE: Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: jvbochove@onenet.an
Posted on Jun 27, 2008
quang123
  • 107 Answers
SOURCE: Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Posted on Dec 04, 2008
SOURCE: 8mm/Hi8/Digital 8
As this was quite some time ago, you probably already have your solution, but I just ran across this. Just in case you can use any other 8mm camcorder or deck if you can find one. Also if you still had it I would like to buy the Instruction manual from that old Canon ES780. Please write me back at bpgray@verizon.net if you have it. Thanks.
Posted on Dec 31, 2008
Sony Handycam CCD-TR517 8mm Analog Camcorder
you can do that with EASYCAP usb2, a camcorder video capture card card " USB Convert VHS Tapes CAMCORDER to DVD Capture 0" , on ebay from wanghaostore. 10$. works perfectly, useful to digitalize VHS tapes too.
Jul 22, 2010 | Sony Handycam CCD-TR517 Camcorder
Loaded tape into Samsung VP-L700U 8mm and received 'Emergency Eject' message. Tape now chewed. Repeated & ruined several new & used tapes, including cleaner tape. Camcorder was working a half...
Internal mounting screws for the tape chassis may have come loose and can no longer hold the tape in the correct position. You will need to disassemble the camcorder to access the tape mechanism.
Nov 15, 2017 | Samsung VP-L700U Camcorder
I have a really old Canovision8, E40, 8mm camcorder that doesn't work anymore. What's the best solution to convert the tapes to DVD or to the computer?
You need Hi-8 camcorder/ Hi-8 player to playback your old Video-8 tapes, hook that camcorder/ player with DVD Recorder, play video-8 tapes and burn DVDs directly.
Dec 27, 2009 | Canon ES400V Camcorder
Old GE 8mm camcorder-no color when playing old tapes
Yes, this sounds like dirty heads, typical symptom for analogue 8mm.
Yes you can clean the heads. It's a delicate procedure, but, requires no disassembly. To clean your heads, I would run to Radio Shack and buy cleaning fluid refils. Take a Qtip and dampen it with the cleaning fluid. Open the camera, remove the tape and look for the video drum. Lightly rub the Qtip along the drum horizontal to the spin direction (not across the grain). Turn the drum and clean until you have swept the entire circumference.
May 03, 2009 | Video Cameras
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
Nov 01, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Video 8mm player
only sony really supported 8mm look for any trv model cam on ebay etc and make sure you tapes were hi 8mm-not digital 8-digital 8 won't play on reg 8mm cam-need to get model that supports both formats then-trv480-look at tapes and if they say digital and/or hi 8 they may have been in digital and get the 480 it will work with both types
Aug 24, 2008 | Video Cameras
8mm/Hi8/Digital 8
Dec 14, 2007 | Canon ES870 8mm Analog Camcorder
Tape compatibility question.
Yes. Hi8 camcorders are manufactured to work with 8mm or Hi8 tapes. The difference is the quality of the tape. 8mm tapes will provide about 270 lines of resolution where a Hi8 tape will provide up to 400. For better quality recordings, you'll want to use Hi8 tapes.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Cameras Logo
97 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
