Question about Dryers
Dryer gets extremely hot and stops mid cycle. starts again after allowed to cool down for half hour. this happens on all heat settings. there seems to be pleanty of air flowing to outside thru the vent. does this mean it is not clogged?
  • Dryers Master
  • 7,482 Answers
Sounds like one or more of the thermostats/thermistors are faulty.
This is a symptom of faulty thermostat/thermistor.
You can check the thermostats/thermisters using a ohm meter.
Remove the wires from one at a time and check with the wires removed, it should read continuity.
I will include some other things to check also.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause thermostat/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Jan 03, 2011
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
Dryer stops mid cycle
Do you have a blocked vent hose?
Oct 18, 2013 | Maytag Dryers
My Amana Electric Dryer Randomly stops working and it won't start up again , it can take up to an hour for it to work again. Model Number LE8407W2.
There are safety sensors that will break the current when it gets too hot or if the sensors themselves are failing. This will shut the dryer off or make it quit heating. After cooling down or at random times the sensor may make connection again allowing the dryer to work. These can only be checked out using an OHM meter and must be checked when they are not allowing the dryer to run.
Jan 22, 2013 | Amana Dryers
I have a Whirlpool LER4634J Electric Dryer that has stopped mid-cycle and will not restart. I know VERY LITTLE about dryers so please use plain language if you give suggestions about how to fix it. Thanks!
1. Does it have electric power? Is the breaker or fuse good? Is the power plug loose?
2. Is the door to the dryer ajar? Please open and close it a few times to check this.
If this doesn't help, you may need new or repaired parts. The timer motor that turns the dryer switch may have failed. The clutch that allows you to turn the select knob for the different dryer cycles may be slipping and have failed. The start button that begins the dryer cycle may have failed after a temporary power outage. The door switch may have failed. The particular switch in the dryer cycle setting you are using may have failed (Other cycles may still work). The dryer thermostat(s) may have failed (prevents too hot/ over-heating). Follow the wires from the "heat selection switch" to find thermostat(s) in the hot air duct. They "turn ON" when too cool and "turn OFF" when hot enough. Mechanical switch contacts can "melt together" and stay always ON. Or switches can get pitted and stay "always OFF" after enough ON/OFF cycles. If pitted contacts happen, you can see this on them. Sometimes a finger nail file (I do not recommend a metal one) can shine them up again. Solid state (electronic) switches have to be tested with a meter or something else to see failure. Please don't do work on electrical or any other problems while the dryer is plugged in or still hot. Good luck. Your mileage may vary. ;-)
Aug 03, 2010 | Whirlpool LER4634J Electric Dryer
My dryer will run for about 20 minutes and then shut itself off. I cannot turn it back on for at least an hour as the 'done' buzzer will buzz and the dryer will not turn back on. Does anyone have any...
If it happens during the auto-drying cycle, the moisture sensor could be faulty.
If it happens during the timed cycle, the operating thermostat may be faulty. A faulty operating thermostat can fail to turn the heaters off and allow the dryer to get too hot. When this happens, the high limit thermostat will turn off the machine. After it cools down, it will start again.
Apr 28, 2010 | Dryers
My kenmore 90 dryer will stop. It is like it
The operating thermostat has most likely failed. When the dryer heats up, it gets too hot and the high limit thermostat turns it off. When the machine cools down, it will start, again.
Apr 17, 2010 | Kenmore 64742 Electric Dryer
Push start button but nothing happens but buzzing noise
Is Kenmore a Whirlpool?
  • Here is what happened.
  • Stopped running mid-cycle.
  • Dryer set idle for about two hours Then I pushed start butten again.
  • It ran fine to finish load.
  • Next load it was totall dead and silent and remains that way.
  • The vent hose was unobstructed.
May 04, 2009 | Whirlpool Dryers
My gas dryer has stopped heating up.
More than likely the operating coils are getting hot and opening. If it heats a little tomorrow after cooling back down but quits again replace these critters:
Dec 15, 2008 | Dryers
Won't Stop
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is
cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher.
Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature
of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than
120 degrees Fahrenheit.
Aug 03, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dryers Logo
123 people viewed this question
Top Dryers Experts
