Question about Zanussi Washing Machines
Zanussi washer dryer showing e20 error message in dryig cycle
    Brigadier General:
  • 3,917 Answers
Hi
This means that the filter is clogged. Unscrew the filter it'll be full of lint. E20 also means drain problem. If it actually goes through the Spin cycle then there is most likely some water still not drained out at the time of the tumble dry. Check the drain and the hose to make sure it isn't clogged.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 03, 2011
My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
Cycle stops and shows error E20. Cylinder hold water and does not drain or complete cycle
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
If still the problem persists then the problem is with the draining pump.The pump is not pumping out the water.Check the pump impeller it may got stuck due to some obstacles.Replace it and this wont come again.
Sep 16, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi progress 1200 WASHER DRYER
This means that the filter is clogged. Get a towel (or two) in our case, and then unscrew the filter. It'll be full of lint.
Dec 26, 2007 | Washing Machines
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Error code 20
Hi, I also got the error code E20 when the filter became totally blocked during the washing cycle (due to a pair of my son's old work jeans!). Once I cleaned out the filter everything worked ok again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there. Regards, John
Sep 04, 2006 | Zanussi ZJD1219 Front Load Washer / Dryer
Washing Machines Logo
275 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
