Question about Aiwa AWP-ZX7 CD Shelf System
MY AIWA MINI COMPONENT NSX VC920 TR REGULATOR A1266 WHICH SUPPLY 5V TO MAIN CPU IS BROKE I REPLACE IT NOW SOME TIME IT SHOW PTS19 (WOULD BE PROTECT 19) AND SOME TIME SHOW PTS 20 AND THEN CUT OFF SOME CAN USE AUX AND HAVE GOOD SOUND BUT IF I TURN TO TAPE PLAYER IC 101 MAIN CONTROLLER TURN VERY HOT I THINK THIS CAUSE TR A1266 BREAKS (IT VERY HOT TOO) SO I USE RESISTOR 4.7 OHM PLACE AT EMITTER BEFORE THE CURRENT OF 5 V TO IC101 (THE DISPLAY CONTROLLER) AND USE 22 OHM AT COLLECTOR(12V GO TO THIS PIN) THE HEAT DECLINE BUT NOT GOOD SO I LOWER IN PUT VOLTAGE AT 220 VOLT BY PUT 220V 100WATT TUNG STAIN LAMP IN SERIES IT BETTER BUT NOT THE BEST ...HEAT STILL REMAIN I DONOT THINK C101 IS SHOT BECAUSE DISPLAY CAN SHOW DEMO PL PL SHOW THE SOLUTION TO PUBLIC I NOT SURE MY E MAIL ADDRESS STILL OK OR NOT
2 Suggested Answers
robotek
  • 1512 Answers
SOURCE: aiwa mini-component
gidday mate... it does sound like a failure in the audio output stage. I suggest that you first check the speakers for short circuits as a fault here will produce a similar symptom you described. Check that you have the correct DC conditions about the STK, such as main power supply. Check all resistors that are in proximity to the STK, particularly lower value ones. Look also for shorted or dry capacitors about the output stages. Most of the audio signal path amplification is inside the STK and generally only a few millivolts of audio are provided to the input pins(usually the outermost pins). I have looked online for a data sheet on the chip that may be of help to you, but have not yet been able to find one. If the unit has soft touch electronically switched input selectors or electronic attenuator to the vol control, either of these IC,s may be faulty also. I am happy to keep going with this to help you fix it if you want. Give me a hoy back in here and I will :)
Posted on Jan 25, 2008
Tc 290 tr my old tv suddenly stop,now power allso not on
main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 15, 2016 | Televison & Video
AIWA TV NO POWER SITUATION
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Power supply stage circuit to many popular brand TVs and others are given.
Oct 16, 2014 | Aiwa Televison & Video
Power indicator open but no function audio,as well as selector my unit is an aiwa nsx k880 stereo
To start with you will have to check on the power supply for the fuses, the fusible resistors on the various sub power section near the main transformer. If OK proceed to see the recitifed DC , the supply to the main controller IC the microprocessor in the front panel. You will need some basic electronics to check for the +5 volt to the mP and confirrm if it is working. replace only if confident or get help. If this section is OK then proceed to the mode selector IC to the output IC. This may require some good technical support to prevent further damage by tampering so please check this out. Good day
Jul 26, 2010 | Audio Players & Recorders
I has a aiwa nsx -999 component set it has a burnt transistor in the regulator area i dont know the part number
if the part number is not on the pcb bord then you need to get a sqmatic diagram and find it there
Apr 24, 2010 | Audio Players & Recorders
NO POWER IN MY MINI HIFI AIWA NSX SZ2HR
hello glass fuse may blown inside take the cover off you should see glass fuse in the power supply
shaun
Oct 22, 2009 | Aiwa AWP-ZX7 CD Shelf System
I have two aiwa nsx-d737 stereos with basically the same problem. On the one, the CD tray will not oepen and the display shows that it is playing a CD when it's not. On the second one, the CD tray will...
Hallo! Mayby you can sell my one of your aiwa nsx-d737 stereos? I've been dreaming to get it for a long time, but I can't find it nowere in Russia. I ready to pay all transportation costs and expances. May I also ask you to write me back on e-mail zhivulko@gmail.com even if you can"t or do not want to sell it?
A milliomn thanks))) Olga
Jul 13, 2009 | Aiwa Audio Players & Recorders
Need a replacement belt for Aiwa NSX-A777
CONTACT ANDREWS ELECTRONICS AT WWW.ANDREWSELECTRONICS.COM, THEN CALL THE CUSTOMER SERVICE LINE THEN TELL THEM WHAT YOU NEED.
Feb 24, 2009 | Aiwa NSX-A777 Shelf System
AIWA NSX-2700 Alarm
On the remote hold shift and press timer button.
It should go off.
Hope this works for you
Kurt
Dec 27, 2008 | Aiwa NSX-2700 Shelf System
Aiwa AWP-ZX7 CD Shelf System Logo
139 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
