Question about Sansui 19 in. LCD TV
TV IS NOT WORKING PROPERLY - Sansui 19 in. LCD TV
    Sergeant:
    Champion:
  • 342 Answers
What is your issue tell me more and i will help
Posted on Jan 03, 2011
I bou kodi box not working properly
If your Kodi TV Box isn't working properly, you can try fixing it with this guide: Fire Stick Kodi Not Working Fix FireStick Fire TV Now KFire TV
Jan 03, 2017 | Televison & Video
My LOGIK L22DVDB19 was working O.K. We had to turn the Power-Off for work to be carried out. When the POWER was turned back on, everything worked save for the TV?- No red light on: can anyone help?
Check that the power cables were properly seated to the power board internally. If your TV is not starting at all, then likely this occurred, or that the cables are not seated properly to the TV. Any number of things can happen when you do servicing to the TV, assuming that had happened.
Jan 15, 2015 | Televison & Video
I get only black and white picture
Dear Zak Nkosi.1) First Of All You Must Check Your TV Card That Properly Plug in Your PCI Slot. 2) Then The TV Card Drivers Is Mach Your Window Version And Properly Install, Some Driver Did Not Work In Every Type Of Windows,3) Must Check Your Antenna Cable That Properly Plug With TV Card, 4) Some Time The TV Player Is Not Work With The TV Card Driver, So Check With An Other TV Player,NOTE:Its Very Important That You Have Tested TV Card With Latest Drivers.
Nov 14, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
ENTER saa7130 tv capture card not working properly
You need to make a cable with both ends with 3.5 mm jack socket. Plug one jack socket in audio out from tv tuner and the other in the line in from your sound card and will work.Good luck
Apr 01, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
REMOTE CONTROL DOES NOT WORK ON TV, NEITHER DO THE TV KNOBS. WHAT IS THE CORRECT SETUP FOR TV TO CABLE BOX CONNECTION. WHAT ARE ALL THE PLUGS THAT ARE NEEDED FOR THE TV TO WORK PROPERLY. THIS TV WAS...
As far as your TV is concerned if everything seems to be working properly other than remote or buttons not working you might have a stuck button. Press on them individually and see if they click.If you find one that doesn't you may be able to work it until it pops out.fe41745.jpg
Mar 02, 2010 | Televison & Video
We cant get a signal on the tv and it wont work
If the tv powers on correctly, then recheck all wire connections (including ac cord) are in proper placement and fit. Make sure the DVD is working properly and is connected properly to the tv. Visit the tv menu and check all settings for input signal. Be sure to have the correct "input source" set on your tv.
Jun 13, 2009 | Hisense TL1700 17 in. LCD Television
Ps3 wont work on lg tv with hdmi cable
With the PS3 and the TV properly connected and both units off turn on the TV and set the input to the proper HDMI setting then press and hold the power on button on the PS3 until it beeps twice. This should resolve your issue. Please let me know how it works for you.
Feb 26, 2009 | LG 32LX5DC 32 in. LCD TV
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
Sharp 27F-630 27" TV
Dear eligas1312, Most probably your antinna is not reciving TV signals properly.Try to adjust it in a right direction at a proper height, also adjust frequency of various channel of Direct TV through menu button. regards ajay
Aug 04, 2007 | Sharp 27F-630 27" TV
Sansui 19 in. LCD TV Logo
19 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
