I need one of my gemini cdj-203 cd decks fixing ! it wont read disks at all is there anywhere i could get a replacement disk drive or lazer unit ? am confidant of fitting it my self if nesseary then take it for nessery tests by a local registerd electrition but ad rarther get the work done by a proffesinol if a can i live in the north east of england MIDDLESBOROUGH if theres somewhere near that can deal with my problem grait! if not a dont mind sending it away by post
  • 675 Answers
Open the unit and look inside at the laser assembly...It should have a number on the assembly near where it plugs in...it may have a "KSS-XXX" number on it( where xxx is numbers). There is an electronics company we deal with that sells all sorts of lasers for cd/dvd unit...find this number and you can go to mcmelectronics.com to see if they carry the laser...it is very easy to install, but you will need to remember that there is an area on the new laser where they short out the laser assembly with a solder bridge( they do this to keep it safe from static discharge). You will need to remove this solder bridge before using. Replacing the laser itself is very simple...usually thewre will be a couple of rails that the laser rides on and one (or both) will come off with a clip. Simply slide the old laser off..plug in the new one...remove the solder bridge(as mentioned above)..and install the new one back on the rails.
Posted on Jan 03, 2011
My does my cdj keep skipping on track 1 and 2
Try a head cleaner first and if that doesnt work then look around for a new cd player or use the computer as if its what i think it is then its not reading correctly and it not really repairable ,Well financialy viable as i think the memory reading of the circuitry is questionable.
Dec 06, 2011 | Gemini Sound Products Gemini CDJ 203...
Hi. How do I fix a CD deck that wont open if I press eject? The deck refused to open with a CD inside. The deck wont play the CD if I press play and wont eject if I press eject. please help. Thanx TC
To retrieve the CD safely, the safest way is to open the unit. A common problem is that a tiny belt from a motor that drives the eject deteriorates and slips so there isn't sufficient drive to move the mechanism. The unit is probably in a mode expecting to eject and has commanded the motor but it doesn't complete... Do as I say and open the unit to do the retrieval. Then get unit serviced.
Dec 04, 2010 | Gemini Sound Products Gemini CDM-3700G /...
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Aug 09, 2010 | Pioneer CDJ-200 CD Player
My cdj citronic mpcd-s6 keeps saying disc error when puttig cd's in, but work on the other cdj.
i have the same problem, i do not know how to fix it. i have 2 of them and one plays fine whilst the other does this
May 05, 2010 | Audio Players & Recorders
I hve a gemini cd 200 and the left deck stopped reading cd's. when i put in a disk the lcd reads no disk. What cuold be the problem.
Just like with any CD player, the optics have lifetimes. Either the optics are dirty and can not read the disk or they have failed. These units use KSS-213 optics assemblies from Sony, if I remember correctly. These can be purchased for around $25. Any one with audio repair experience should be able to replace them for you.
Dan
Jul 31, 2009 | Nu Mark Numark CD-Mix-2 Dual CD...
Cd mounts but doesn't start on cdj-100s
hii,
you need to replace complete assy. of ur decks.
thx,
djajay
Jun 09, 2009 | Pioneer CDJ-100 Turntable
Pioneer cdj 200 wont read discs
Hi, try cleaning the lens with a cleansing disk. if this doesn't produce results, it will confirm a major issue within the lens assembly. you will need to replace the lens assembly in this case. it is unable to track or read in this damaged sate.
May 19, 2009 | Pioneer CDJ-200 CD Player
Not recognising that there is a cd in there. keeps saying 'no disk'
Hi there , have you tryed cleaning the lazer lens very gentle with a cotton bud , the lazer could be quite costly to replace , there is a very small ajustment on the lazer inside the unit but would need someone with a bit no how to ajust the setting a very small amount to see if the lazer will work better .
May 10, 2009 | Audio Players & Recorders
104 people viewed this question
 Grubhead
Grubhead
