Question about Health & Beauty
I NEED TO GET HOLD THE PADS FOR SEIN TENS SE33
I am greater than 3 hundreds, 2 tens, and 2 ones. I am less than 3 hundreds, 2 tens, 4 ones. What number am I
Let's build the two numbers in question.
HTO for hundreds, tens, and ones
322
324
What number is greater than 322 and less than 324?
Good luck.
Paul
Nov 12, 2015 | Office Equipment & Supplies
Rear brakes on 2011 kia sorento
Try a question rather than a statement.
I also give you the below from another answer:
Buy a Haynes or other manual. You need the pictures, dimensions, specifications and torques. DO NOT JURY RIG OR GUESS ON BRAKES. The fact that you have posted here for the entire world to see, if your brakes are not spot on and you hit someone, you will lose everything you hold dear in the subsequent lawsuit.
Jan 03, 2015 | Kia Cars & Trucks
NEED INSTRUCTION MANUAL FOR BIO MED 2000
To contact them via the web, http://www.bmls.com/contact/contact.php
A general "how to" comparable to what most manuals show is here:
http://www.drugs.com/cg/how-to-use-a-tens-unit.html
and
http://www.thephysiotherapysite.co.uk/physiotherapy/pain-management/how-to-use-a-tens-machine
And a video here:
http://www.youtube.com/watch?v=SmfxlTXF73w
These will tend to be general, the reason is they are prescription devices, and misuse can kill you. Your doctor or chiropracter should show you the specific manner in how to set it up for your condition. If you set the pads in the wrong locatation, you can also suffer severe debilitating cramps in the muscle groups between the pads for several days after use too.
Feb 04, 2012 | Cars & Trucks
I need to replace my seine board on my toshiba 42hl167 tv and need to know how to do it
What is the sein Board? I'm guessing you mean the signal board since you are also talking about updating the firmware. Signal boards are not too hard to replace on an lcd TV depending on your abilities. You can do a search for a service manual on the internet it will give you detail instructions on how to replace the board.
You can get parts at www.interliquidparts.com
Dec 05, 2011 | Toshiba 42HL167 42 in. LCD Television
WAS IST HPSU-0004 WIE KANN ICH ES INSTALLIEREN
Hi!
Erstens verzeih mir bitte wegen Schreibfehler. Meine Muttersprache ist nicht Deutsch.
Jetzt zur loesung:
1. Auf der support-seite von HP suche und lade herunter die (sehr grosse) Datei welche die FULL drivers und applications fuer dein Drucker beinhaltet;
2. Starte die gerade heruntergeladene Datei bis zum Punkt wo es anbietet die software zu installieren;
3. Click NICHT auf "Install", sonder verlasse den Installer (z.B cancel). Am diesem zeitpunkt haben wir auf die festplatte alle spaeter notwendige Dateien;
4. Jetzt finde den Ordner wo alle diese Dateien gespeichert wurden. In diesem Ordner soll der Ordner "setup\hpupdate" sein. (der Ordner musste in TMP oder TEMP sein - am besten verwende die option SUCHEN;
5. Nur nachdem du den Ordner gefunden hast koennen wir fortsetzen:
6. In Windows Systemsteuerung, programme entfernen, werden wir das programm"HP Update" entfernen. Kann sein dass mache Fehlermeldungen dabei entstehen, aber das ist normal unter diese Umstaenden
7. Jetzt gehen wir zurueck zu dem Ordner den wir bei Schritt 4 gefunden haben. (setup\hpupdate), und doppleclick die einzige *.msi Datei die es dort gibt. Dadurch wird die HP Update Utility neu und richtig installiert;
8. Wenn die Installation (Schritt 7 ) vollendet ist, kann die HP-Update utility ausgefuhrt sein, um updates fuer alle Deine HP anwendungen zu erhalten.
Hoffe es war hilfreich
Beste Gruesse!
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
What is the answer of this problem? I am a four digit number. My ones is twice my tens. My hundreds is five less than my ones. My thousands place is the sum of my tens and hundreds. What number am i?
There are two possible answers to the above question, 4136 and 7348.
4136
My ones is twice my tens: The 6 (the ones) is twice as big as the 3 (the tens).
My hundreds is five less than my ones: 6 (the one) - 5 = 1
My thousands place is the sum of my tens and hundreds: 3 (the tens) + 1 (the hundreds) = 4
Jun 26, 2011 | Office Equipment & Supplies
Need to fit new brake pads to 2008 flhr road king
I believe there are bolts that hold caliper together 3/8 12 point socket works this was the case on my 93 fl.. the 1/2s separate which will give you access to the pads..good luck..I have found good info at harleytalking.com
May 26, 2011 | 2008 Harley Davidson FLHR Road king
Removal of front brake pads
The noise you hear is normal when it's time to change the pads. After you've purchased your brake pads (usually $20-30 depending on where you go, quality, etc), take your front tire off and take the 2 bolts out that hold your brake caliper on. You should be able to lift the calipers upward above the rotors and remove the old pads (they just snap in). Be careful not to put too much stress on the line connected to the calipers as these lines are full of brake fluid. Breaking or cracking this line is not good. Just hold them in one hand as you change the pads. When you put the whole thing back on the rotor, you'll need to compress the pads, otherwise they won't fit. I usually use a long screwdriver and pry the pads back. This will ensure you will be able to match the holes up for your two bolts to go back in. Repeat on the other front wheel. Hope this helps.
May 22, 2009 | 2007 Toyota Yaris
Health & Beauty Logo
161 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
