Question about Miller Welding Tools
I have a miller 255 nig .the welder will start to weld and stops gas flow is working the triger is working . You can relase the triger and start it again it willweld about 1 inch and stop emall unionroofing@hughes.net thanks Blake
  • 407 Answers
Sound like you have a machine programed on stitch mode, to override the program do the following:
1)Turn off the machine
2) With the machine turned off press the gun trigger.
3) Turn on your machine keep the trigger pressed, hold it for about 3-5 seconds. Depress the trigger and you should be good.
Posted on Jan 04, 2011
Miller syncrowave 300 no power light and no weld power however have 480v input fan runs and can hear gas start when foot petal pushed
bad computer-its an authorized dealer thing-you can pay 1-200 to get it figured out or buy a HF flux core welder for same price.
yeah-Im all blue in my shop and I said HF...
i would pay the miller dealer to get it fixed.
Mar 05, 2014 | Hobart Handler 140 Mig Welder
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
After completing a plug weld on sheet metal the molten weld grows to a point as it cools
This is a gas issue. Either you're running out of gas, or there's junk built up in the tip of the gun, keeping the gas from flowing freely. Also, if your arc length is too short, this can happen but it sounds like a gas problem. If the gas isn't an issue, try backing off a little when you make a weld, or turn your wire speed down a hair.
Jul 09, 2011 | Miller matic 140 Mig Weld Package...
I have a miller maxstar 140 str that does not work I get no weld output. the ready light comes on initially then fades and blinks once.
i have a miller 210, when i pull triger it makes clicking noise and does not feed wire, then when i pull trigger again it works, does this sound like a gun problem or controller problem
Feb 03, 2010 | Miller Welding Tools
Gas won't shut off until power is shut off
With a tig welder it is designed to do this. The gas is used to shield your weld of all airborne contaminates. Your welder should have a flow on start of weld and what they call a post flow. This post flow protects your finished weld from contamination. You can preset it from 0 to 30 seconds on a majority of welders. I would recommend you set a postflow for at least 10 seconds and hold the torch above your finished weld until gas shuts off. It is doing this for a reason! Too Protect your weld from oxidation and other contaminates while the molten weld pool sets up! Hope this helps out!
Dec 28, 2009 | Welding Tools
No constant gas flow...
a hole in your gas line or the solenoid is sticking
Jul 30, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
No gas flow
You never mentioned switching the polarity, this must be done when switching between wire types, Connect polarity appropriately, for steel use dual mix carbon dioxide/argon and set flow to 25-30 and give it shot. Good Luck!
Mar 20, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
Tig my pudle melts into gray not shinny
Ensure you have the correct angle when using the torch = 22-24 degrees from vert: this will provide good gas coverage. setting should be 15 - 20 ltrs using a "flow meter".clean the material thoroghly then weld , dont clean then leave for a long time.
Argon gas sometimes can be contaminated and cause heavy soot on the weld bead,
TIG electrode should be Zirconiated with a rounded end not pointed.
Use forehand ,method
Feb 02, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welding Tools Logo
141 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
