The start button on my washer dryer AWZ510E keeps flashing green.i have heard if i can get the control pad command sequence it can be fixed? thanks
  • 1 more comment
  • Lisa Kavanagh Jan 03, 2011
    whirlpool AWZ510E washer/dryer, start button keeps flashing green, will not run any programmes ,not even drain/spin, just flashes. have heard if i got control pad command sequence might help. ta for all advice, these things cost a fortune to fix in ireland!
    ok so tried, at off/0 it still flashes and makes no difference when turn it then to drain/spin..so new control board i guess. thanks for help, was worth a try
    thanks so much. left unplugged for 24 hours and still...just flashing! thanks, i get cracking on a control board, appreciate help.
  • 10,515 Answers
This is a common problem on Whirlpool washer dryer. It sounds as though your control may be a little confused or faulty. Try unplugging the washer and the plugging it back in about 10 minutes later.If there are no flash codes and there is nothing happens - i.e no beeping or noise, more likely control board is at fault and needs replacement.On few occasions, the small plastic piece behind the start button is missing. However, these are the main 2 probabilities.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 03, 2011
  • taran_2005
    taran_2005 Jan 03, 2011
    Thanks for your response!!
    Unfortunately, other the unplugging and replugging, there is no reset on this machine that i am aware of. If some other lights would have been flashing or control is locked, there are certain reset options. But, if the control pad is dead, other than opening the machine and checking the ribbon to make sure that it is not damaged, there is no other option. Be advised on few occasions, the small plastic piece behind the start button is missing.
    Hope i helped you.
  • 4,323 Answers
Hi
To reset turn the program selector to "Off/0" and select the "Drain Spin" program to remove the water remaining in the bowl before the door can be opened. If this won't solve the issue then you'll have to replace the control. Hope this helps...please post back for further assistance.
Daniel
  • Daniel Scott
    Daniel Scott Jan 03, 2011
    Thats the reset sequence....gave you earlier and as I told you if it won't work then the control board should be replaced
  • Daniel Scott
    Alright then you can rate this solution as I can see two thumbs rating
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Says "Controls locked"
Press and hold the END OF CYCLE button for about ten seconds.
Nov 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Our Kenmore Elite Dishwasher has a blinking green light next to the clean cycle. It won't reset. We changed the motor and this has been going on ever since. Do you know what we need to do to fix it....
Hello
Blinking green light can be reset by following two buttons in sequence: press HIGH TEMP WASH-HEATED DRY buttons in sequence around 3-4 times so that the control reset itself. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Kenmore Elite 45986 Front Load Washer
Canon ip1600 showing message that waste ink absorber is almost full and stops the printing process. How to correct?
First you need to remove that inpad carefully from under the cassettes. Press power on so cartridges move out. Pull out ppower cord to prevent it going back to base. Using tweezers, remove the pad. noting how it is positioned. You can use a few drops of bleach and water to soak the pad in to remove the ink. Then pat it dry between two rags and use a hair dryer to fully dry it. Take care not to burn it.
Then, replace it. Repower the machine.
Now follow this sequence to reset the counter.
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
and you have just saved $150 in service fees
Please rate my help++++Thanks for using FIXYA
Jun 10, 2010 | Canon PIXMA iP1600 Printer
I cannot unlock the commands ; the red light ( paddock ) is on
Push the HeatDry and High Temperature buttons at the same time
Then:
punch these buttons back and forth until lights light up (about 5 times) then:
Hit cancel
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sharp AR-5316
Never heard of an F2 on that machine. But give this a try.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
