Question about Goodman Heating & Cooling
My furnace wont come on unless you turn it down then back up again. Its set at 72..but you have to turn it down then it will heat up..and you have to keep doing this unless you want to freeze!
    Genius:
  • 1,015 Answers
The first thing I would do is change the thermostat and go with the least expensive manual heating cooling stat I could find and see if that helps,Thank you
Posted on Jan 03, 2011
Furnace wont keep kicking back on. On its own, led light does blink 3 times stops and blinks 3x again
Without knowing fuel or model, it could be bad relay in primary control or loose wiring, on either power or t-stat side.
*I never recommend homeowner attempt to repair/replace any parts on heating appliance. Any information is strictly to educate homeowner on functionality. Always contact a heating professional for service and annual tune-up.
Feb 13, 2016 | Heating & Cooling
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
I have a Coleman EB12A electric furnace. The Air is working, but the heater isn't. 3 days ago I turned it on. Set it at 72, it ran for a hour then it stopped. It hasn't ran since no matter were I set the ...
  1. Look for a red button somewhere on the heat ex-changer. Its a high limit safety that trips if the furnace gets too hot. If that does not click when pushed, cut the main power for a minute and try it all again. Let me know if it starts up.
Oct 02, 2013 | Heating & Cooling
The thermostats current setting does not match the current temperature and the heat will not turn on. the temperature is at 65 degrees, but the setting is at 72 degrees. the switch is set to heat and it...
Sounds like you have a problem with the furnace try turning the power off to the furnace and then turn it back on to see if this will get it to run. If it has a sight hole in the bottom door look to see if there is a flash code. then take off door and see what the flash code represents as the problem.
Dec 17, 2009 | Honeywell Programmable Thermostat Heater
My heater will kick on right away but after 3-5mins it stops producing heat then a few mins later it will start heating again. Why?
The furnace could be shutting off on High Limit ...means your furnace is running too hot...check your filter and make sure return air vents are clean and clear....also it can be the Heat anticipator in your thermostat...which controls how many times your furnace cycles...basically your furnace should come on and off 5-6 times/hr ....need more info on your type of furnace and type of thermostat
Oct 19, 2009 | Holmes Products HCH4062 Ceramic Compact...
Furnace starting
Hint number 1, get HVAC license. One mistake or misunderstanding and you could blow your house up.
Feb 21, 2009 | Heating & Cooling
Furnace not cycling properly
sounds like the flame sensor needs to be replace. You can try cleaning it with steel wool. This will get you by for a little while.
Jan 17, 2009 | Honeywell Electronic Programmable...
Furnace burner turns off and on
The furnace is likely over heating and the high temp. safety is shutting it down. It then cools and starts again. Things to check: Filter, Blower wheel and indoor A/C coil. If any or all are dirty you are limiting air flow and need to clean them.
Jan 17, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
