Question about Sharp Microwave Ovens
I need to know how to set the clock for the R209BK microwave. Thanks!
  • rainbomama Jul 11, 2008
    Thank you! That worked.
  • Sharp Master
  • 9,098 Answers
Normally you press Clock, then enter the numbers, then hit Clock again.
If that doesn't work, try this similar owner's manual.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 11, 2008
Hi I am having problems setting the clock on my cooker could you please help thaankyou
HELLO.
solution on setting your microwave clock is explained below.
This is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be off.
  1. Touch Clock.
  2. Touch the number pads to set the time of day.
  3. Touch Clock or Start.
Thanks.
Sep 21, 2011 | Microwave Ovens
I am having difficulty setting the clock on my Baumatic BAF9006 90cm dual fuel cooking theatre can you please help
HELLO.
Setting your microwave clock is explained below.
It is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be put off.
  1. Touch Clock.
Thanks.
I do not know how to set the clock - can u help pls.
HELLO.
The solution to your problem is detailed given below.
To set:
  1. Touch Clock.
Thanks.
Sep 20, 2011 | Microwave Ovens
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How to set the digital clock pls
Without your model number this is a GENERIC answer that is applicable to MOST microwave ovens.
1. Press Stop//Pause
2. Press Clock
3. Set Time
4. Press Clock
Time is now set and the Microwave is ready for use.
If this does not work.. I need you to respond with your model number to look up your exact steps.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Microwave Ovens
I have an LG Intellowave microwave model MS1942G and would like to know how to reset the clock please.
Push button that says 'clock' then use the '10min' button to set hour, '1min' to set 10 minute intervals, then '10sec' button to set minutes. Click 'clock' button again to save. The trick is to make sure the the colon like dot separator on the clock is flashing when you try to make changes. Did my head in working this out... in the end I had to ask my wife...
Sep 11, 2010 | Microwave Ovens
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Dont know how to set clock
hello there:
to set the time on you're micro wave you will need to push the clock button and use you're number pad to enter the time and once you have got the time set properly you will need to press the clock button again.... hope this helps you out sincerely D.Jones
Jun 06, 2010 | Goldstar MV-1501 Microwave Oven
How to set clock
Try these combinations:
Clock > 1 > 2 > 3 > Clock
Clock > 1 > 2 > 3 > Start
Clear > Clock > 1 > 2 > 3 > Clock
Clear > Clock > 1 > 2 > 3 > Start
If that doesn't work, contact the dealer you got it from and ask them for contact information for Brandt.
Oct 09, 2009 | Brandt S2600WF1 / S2600BF1 / S2600TF1 1550...
Microwave Ovens Logo
73 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
