Question about Jamo DMR 60 DVD Player/Receiver
DMR 60 insert disc, says loading then says no disc set up doesn't appear when using remote
    Problem Solver:
  • 9 Answers
I had a similar problem: Found two failed electrolytic capacitors on the powersupply of the DMR unit
(One was 1000 microF, the other 2200 microF) Can tell by the tops being slightly bulged out instead of being flat.
Replaced them, now unit is as new.
Posted on Aug 21, 2011
DVD NOT RECEIVING DVD DISCS
Hello
The loading mechanism has the trouble. The inserted CD or DVD does not engage into the laser assembly unit properly. It may be due some fault with its loading motor or loading belt. Check these.
Mar 02, 2012 | Jamo DMR 60 DVD Player/Receiver
The remote just says set 2 and does nothing
Does the TV screen say Set 2 or the display area on the DVD recorder? The original remote for the DMR-ES35VS doesn't have a screen. (If you are using a universal remote, I'm not sure how to reset the unit.)
The Set 2 indicates that the unit was set to listen to a remote on the second wavelength available on these remotes. Your remote needs to be set to the same wavelength. Press and hold Enter and then press and hold 2 (for about 2 seconds) on the remote to set it to this option. Press Return to move back through the menu or exit the screen. (Panasonic provided this feature for those with several devices so that each remote wouldn't control a nearby device at that frequency.) To get the recorder to respond to the remote, they must be set to the same range. To check, press the Functions button. Under Other Functions > Setup > Remote Control Code, you can adjust the wavelength that the receiver is looking for. (Use the up/down arrows to select a sub-menu and the Enter key to enter the sub-menu. Use the left/right arrows to select options in the secondary menu.) If the unit doesn't respond, try a different wavelength. (Press and hold Enter and then press 1 or 3. There are only three possible options for the remote/receiver.)
For a screen capture of this, see page 19 of the manual; it is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRES35V.pdf . An original remote is available from Remotes.com: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DMR-ES35VS&uuid=13262363222670 . It probably comes pre-programmed for Remote Code 1.
I hope this helps.
Jan 10, 2012 | Panasonic DMR-ES35VS
My receiver loading for a while then is saying no disc after i inserted a DVD. This just started happening after i had a movie on pause for a few seconds. Now nothing is playing CD or DVD/
(One was 1000 microF, the other 2200 microF) Can tell by the tops being slightly bulged out instead of being flat. I replaced them both, now unit works like new.
Dec 30, 2010 | Jamo DMR 60 DVD Player/Receiver
DMR-EX98 CANNOT USE DVD RECORD FUNCTION MACHINE THINKS A DISC IS LOADED EVEN WITH NO DISC INSERTED.HDD/VCR OK
This problem has just happened on my dmr-ex98 although perhaps more extreme in that the dvd drive will not read any disc let alone record - makes an attempt to read disc plus phantom disc but gives up. hdd.vcr also ok. Any guidance?
Feb 15, 2010 | Panasonic Televison & Video
Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Jamo DMR61 rejacts the disc for no reason and it doesent load the disc.
Clean the head,if it not load the disc you need to change the head unit.
Aug 14, 2009 | Jamo DMR 60 DVD Player/Receiver
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
Jamo DMR 60 system tray open/close
the remote supplied do not do it.you will need the remote for dmr61 that is updated with the function.i can supply you one brand new for £12 including delivery.i can send you the picture so that you can see the difference yourself.
Jan 10, 2009 | Jamo DMR 60 DVD Player/Receiver
ERROR MESSAGE.....
had the same LD FVU (Load FVU or firmware disc) message and fixed it this way: download firmware from http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP and make firmware disc and insert. After it loads and updates, you need to activate your remote again. When the message SET 1 appears, on the remote press ENTER and 1 together for 10 seconds. Done.
Jun 24, 2008 | Panasonic DMRES15 DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Jamo DMR 60 DVD Player/Receiver Logo
188 people viewed this question
Top Jamo Televison & Video Experts
Greg Cann
Greg Cann
Adorjani Laszlo
Are you a Jamo Televison and Video Expert? Answer questions, earn points and help others
