Question about S.T. Dupont Watches
I have a S T Dupont oblong face with gold glitter in, with croco veritable strap. Battery needs changing but none of the jewellers and jewellery hospitals can get the back off, if there a knack to it.
  • patbrennan10
    patbrennan10 Aug 29, 2012
    Where can I get a Strap for same watch..
Can not get a croco veritable watch strap for a st dupont watch can anyony help
Posted on Aug 29, 2012
To remove the back, you must first remove the leather strap. Between the lugs on the case, you will find 2 small screws. Remove these and the back will come off with ease.
Posted on Jan 19, 2012
What is the value of my Rolex Geneve Ref 59312 watch
fixya doesnt do appraisals --bring it to a jeweler , watchsmith,or notify rolex for an appraiser in your area
Nov 24, 2016 | Rolex Watches
My nooka watch constantly blinks and makes beep sounds. how do i stop this? and why it is beeping?
Hi there! A Nooka watch flashes and beeps when the battery is almost at its end. The battery required is a CR2016. You should be able to get the battery replaced at any local watch repair or jeweler!
-Nooka
Sep 10, 2011 | Nooka ZOT V - White Face - White Strap...
I need a new watch band.
Both metal and leather straps are available over the internet. I, however, recommend going to a jeweler that both sells and installs watch bracelets and straps. This will ensure a proper fit and you will have the opportunity to actually see the styles on your watch before purchase.
Generally, independant jewelers are the place to go for this as chains are too scared of messing up your watch to even change your battery.
Oct 16, 2009 | Fossil Watches
Battery replacement . local jeweler says case is too thin . said to send to manufacturer for replacement
take it to a better jeweler, thats a bs answer. i have changes thousands of batteries and never had that problem. High end stores have better jeweler but the battery prices should be the same. please rate my response
Oct 09, 2009 | Vicence Rectangular Case Strap Watch
I have agents rotary quartz with the number 3081 stamped on the back. the watch is oblong with a black black face and gold lettering and a date box. and gold intergrated strap. Would you please be able to...
Your watch is battery operated hence the term "quartz" All quartz watches are battery powered. As for value I'm not sure. The manufacturer of the module (mechanism inside) is a reasonable indicator of value. If its ETA then its in the upper range. You could try seeing if Rotary have a site if so they may allow you to identify details on age etc from the stamp numbers.
Jul 24, 2009 | Rotary Automatic Limited Edition Dark...
I have two lovely gold vicence watches, one is round with a turquoise backing, the other is oval, or oblong with gold background. They came with a nice leather band. they are pretty stiff and don't really...
Unfortunately Vicence does not do such a service, but do not panic yet, as you can go to the nearest jewellery shop and ask to fit any gold bracelet you choose. Just take your watches with you, because the jeweller will need to get measurements between case lugs and the overall length of the new bracelet and watch to fit your wrist perfectly.
Do not forget to rate, please.
Mar 07, 2009 | Vicence Rectangular Watch
Phillipe Stark PH1079 watch - Can't get back off to replace bat
There is nothing wrong with your watch. The problem is in tools the jewellers are using for opening the watch.
Despite being under one roof, watchmaking and jewellery are completely different trades and are miles apart. Jewellers usually are equipped with very basic watch repair tools and the case openers are no exeption.
You have to find your nearest watch repair shop and ask for watchmaker, not jeweller. Any decent watchmaker will have the right tool to open your watch and replace the battery in a matter of minutes.
Jan 14, 2009 | Fossil Philippe Starck PH1035 Wrist Watch
Mens bueche girod 9k gold watch the gold band is 1 inch short
You have two options and for both you need to find yewellery repair shop.
Option1) Some jewellers sell NOS (New Old Stock) gold watch bands. If your vallet is thick enough for this option- shop around and buy one.
Same jewellery repair shop will be able replace the old band with the new one, even if the band is soldered to watch case.
Option2) In the same shop ask if they can built up (lengthen) the clasp. In this case you will spend less money, but you will loose on looks.
Note: As mostly all gold watch bands are maschine made, it is allmost impossible to repair or lengthen them in a good looking way. Anyway- consult the jeweller first and see what he says. He may have some NOS witch is exactly matching your old watch band pattern.
Good luck.
Jan 01, 2009 | Watches
Crystals framing my Haurex watch face are falling out.
Hi, im a jeweller myself. The problem with jewellers and crystals is simple. Its a lot of work to replace something that doesnt cost a lot to buy (the crystals, not the watch). Swarovski are a commonly known producer of crystals, but you will probably find that simulation gemstones such as Cubic Zirconia are commonly used in newer watches.
I specialise in gemstone setting, and can also work with simulation stones and crystals, but it takes much longer to reset stones into a stainless steel watch case than into gold or platinum so the labour costs are much higher.
It depends how much the watch is worth as to how much you spend on repairs.
Hope this helps
Dec 18, 2008 | Haurex 27473-031-00 Wrist Watch
Watches Logo
262 people viewed this question
Top S.T. Dupont Watches Experts
Ansel Alberto
Ansel Alberto
Are you a S.T. Dupont Watch Expert? Answer questions, earn points and help others
