The keyboard on my Philips x58 printer is faulty. The back arrows, delete and @ buttons do not work. I am using a plug in keyboard Thanks Brian Smith
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Is it possible to change settings on the keyboard?
Yes you can change your keyboard layout.
Go to this link to find step by step directs and also additional optional layouts
http://www.microsoft.com/enable/training/windowsxp/keyboardlayout.aspx
Posted on Sep 10, 2010
SOURCE: Auto shutdown when using the keyboard.
First, please:
What have you already tried?
Please turn computer off for 5 minutes.
Turn back on.
Is the problem still there?
If yes:
Turn PC off
Turn PC back on and, while it is booting, tap the F8 key every other second until a boot mode selection screen appears.
Select SAFE MODE
Does problem still exist?
If yes please return here and let me know
Thanks!
Jimm
Posted on Nov 23, 2012
What is wrong with my laptop? It is as if the shift key is stuck
Go into device manager in windows and delete it and reboot. If it comes back when it detects the keyboard and it works then it was a driver, if it does detect it or it wont work correctly then it is a bad keyboard. You can also try a plug in keyboard to see how it behaves, ps keyboards are not that expensive.
Oct 11, 2015 | Toshiba Computers & Internet
How do I unlock the keyboard on an acer?
try booting it is safe mode and see if it works and then if it does then reboot it again in reg mode. you can also try using a external usb keyboard to have it redetect it again. just a thought.
Aug 08, 2014 | Acer Aspire One PC Notebook
Printer error fuser temp
You can find answers to Xerox questions at www.xerox.com/support
Solutions for : Printer Error Fuser Temp Message There are two configuration options available for this model; the Phaser 3100MFP/X and the Phaser 3100MFP/S. Fax features are only available on the Phaser 3100MFP/X. To determine the configuration of your machine, print a Configuration Page. See the Related Items below for additional information.
Solutions ranked by relevance:
  1. Make Sure the Power Cord is Securely Connected to the Machine and the Electrical Outlet
  2. Make Sure the Machine is Plugged Into a Functional and Stable Power Outlet Test the power outlet that the machine is plugged in to by connecting another device to the outlet. Make sure the outlet is functional and stable. If possible, have the line tested by an electrician. If necessary, plug the machine into another power outlet.
    NOTE: The machine should be plugged directly into the wall outlet, and should not be connected to an extension cord, power strip, or Uninterruptible Power Supply (UPS).
  3. Reset the Fuser Error Solution : Reset the Fuser Error CAUTION: The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable.
    If at any time it is necessary to cancel the procedure and start again with step 1, press the [Stop] button four times.
    NOTE: This procedure will delete all pending jobs that have been sent to the machine.
    To reset the Fuser error:
    (Click on one of the following links to jump to the corresponding section.)
    To reset the Fuser error for the Phaser 3100MFP / X
    1. Press the [Down] arrow (Menu) button on the Control Panel.
    2. Press the asterisk [*] button.
    3. Press the pound [#] button.
    4. Press the [OK] button.
    5. Press the [1] button. ("00100001" changes to "10100001" at SOS1)
    6. Press the [OK] button.
    7. Press the [Stop] button.
    8. Press the [Down] arrow (Menu) button.
    9. Press the pound [#] button.
    10. Press the [T] button on the keyboard. (Do not use the numeric keypad.)
    11. Press the [OK] button.
    12. Power the machine off, and then power the machine on.
    13. Press the [Down] arrow (Menu) button.
    14. Press the asterisk [*] button.
    15. Press the pound [#] button.
    16. Press the [OK] button.
    17. Press the zero [0] button. ("10100001" changes back to "00100001" at SOS1)
    18. Press the [OK] button.
    19. Press the [Stop] button.
    20. Make a copy to check machine operation.
    To reset the Fuser error for the Phaser 3100MFP / S
    10. Press the [Down] arrow (Menu) button until "T>>Printer" is selected.
Nov 27, 2013 | Xerox Phaser 3100MFP/S Laser Printer
X58 pro e hard to cold start
Three long beeps may signify a keyboard error, and 3 short may refer to memory error. These are best guesses, because MSI uses several BIOS manufactures. Test your RAM one chip at a time to help isolate bad dimm.
Aug 31, 2012 | MSI X58 Pro-E Core i7/ Intel X58/ DDR3/...
Hi I just installed the sabertooth mainboard. Strange problem now my usb key works fine in the bios. But when i start w7 the keyboard does not work? Any idea what to do? Thx
Did you install all your drivers. If not you can find them here:
http://support.asus.com/download/download.aspx
Or is it a wireless keyboard,you need the driver for that too.
Or change the boot settings,there is 2 places to do that.
Good luck.
Feb 23, 2011 | ASUS Sabertooth X58 LGA 1366 Intel X58...
I get a "keyboard not
Are you using a PS2 keyboard or a USB keyboard ? Check your connection, if you are using a PS2 keyboard, plug in a USB keyboard and see if that works
Feb 11, 2011 | Foxconn FlamingBlade LGA 1366 Intel X58...
Aspire 5100 mouse is frozen how to fix problem
Try restarting your computer by pushing the windows button on the bottom of the keyboard on the left side, generally next to the ALT button. use your arrow keys to move over to the shut down button, select restart and restart your computer. Or you can shut down and then push the power button to start up your computer. This should help reset your laptop and unfreeze your mouse.
If this does not work, go to the control panel, again using the windows button and the arrow keys. select mouse, then go thru the tabs on the window to make sure that your mouse pad is selected to control your mouse.
If you found this information helpful, please remember to leave positive feedback.
Thank You,
Brian
Jan 26, 2011 | Acer Aspire 5100 Notebook
How do I switch from English to French. There has to be a way of doing this from the keyboard. thanks brian
Hi, a French keyboard is very different to the English keyboard, so for writing in French I use goodle translate and copy and paste into i.e word. The alternative is to plug a french keyboard in place of the English one. Come back to me if this isn't helpful
Jun 24, 2010 | Computers & Internet
I bought a used brian the brain game, and the intstuctions were gone. how can i get it to work
Put batteries into Brian, Hold down the reset button under the upper left corner of the keyboard, and at the same time, hold down the R button on the keyboard.
Jan 01, 2010 | Hammacher Schlemmer Brian The Brain
Accidently uninstalled softtware for the mouse and now have no mouse to access anything. What are my options and how do I get the mouse backé
Switch on the computer and use the keyboard as they did in the pre-mouse days
ie tab key to move around the screen and arrow navigation buttons
Or go out and buy a really cheap USB mouse plug it in and then go get the drivers from the GE website
Nov 20, 2009 | GE Wireless Optical Mouse
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
