Question about Acer Computers & Internet
My Acer emachines computer does not have any sound. I have checked my headphone connection and volume controls. Both of them are all right. It seems that my system cannot detect the sound device. Why is this the case?
  • 675 Answers
Right click on my computer and select the device manager...look down the list to see if you have any exclamation points next to the sound card device...if you see an exclamation you may need to reload the driver for the sound card..you can click on the properties tab for the sound device and there should be a tab to update the driver...try updating the driver...if this dosen;t work..then you may need to pull out the sound card(unless it's on the main board). Look at the sound card to determine what make/model the card is..try going to the website for the manufacturer of the sound card to see if they have an updated driver for your version of your operating system....If all this doesn;t work then your sound card may be bad and need to be replaced...If your sound in built in on the motherboard then there are 2 things you can do...First, go to the BIOS setup to see if the internal sound system can be disabled...if so then you can purchase a separate sound card and install it in a pci slot on the motherboard....Or, if you can not disable the sound, Then you may need to replace the motherboard itself.
Posted on Jan 03, 2011
Testimonial: "Very helpful and detailed solution to my problem. The expert provided a few alternatives, in case one of them does not work out well. "
Acer Aspire 5720 sound turned off
Normally when you remove the headphone off the laptop the sound switches back to the laptop speakers.
Dec 29, 2012 | Acer Aspire 5720 6497 Laptop
When I plug the headphones into the remote on my desktop, you know the one with the volume, base control, on/off and headphone jack my headphones quit working. I just purchased a new dell with win 7 64 bit...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
May 02, 2011 | Creative Labs Inspire P7800 Computer...
My sound wont work on my emachine
There are a few simple things to check first:
  • Make sure your computer has a sound card.
    You must be logged on as an administrator to perform these steps.
    1. Open Device Manager by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. Expand the Sound, video and game controllers category. If a sound card is listed, you have one installed. If no sound card is listed, You will need to install one. See Install or remove a sound card.
      gl_ico.png Note
      If you think you have a sound card installed but you don't see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there.
    3. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
    4. Click the General tab, and then look in the Device status box to identify problems with the sound card.
  • Make sure your speakers are plugged into a working power source and turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a universal serial bus (USB) cable, it will plug into any USB port on your computer.
  • Make sure that the speaker volume is not muted or turned down too low.
    1. Open Volume Control by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
    2. Under Main Volume, move the slider up or down to raise or lower the volume.
    gl_ico.png Note
    Some mobile PCs have an external volume control on the outside of the case. If you're using a mobile PC, check the external volume control.
  • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
  • If you need more help post back!
    Thumbs and testimonial are welcome!
Mar 14, 2011 | eMachines Desktop / AMD Athlon Processor /...
I have no sound on my computer
1. First of all, right click on the volume control icon on your system tray - found at right bottom corner of your screen. check if "Mute all" i selected. If yes, then un-check it.
2. Ensure the speaker or headphone jack is plugged into the green jack-socket, usually found in the rear of the computer compartment. (there are three sockets, green, pink, and blue).
3. Check the power to the speakers. If it plugged properly and switched on.
4. Right click on "My Computer" and click on "Device Manager". Expand the tree of "sound, video, game controllers" by clicking on the plus (+) symbol against it. check if all devices are working fine.
This should help you get through...
Jul 25, 2010 | E-Machines eMachines Desktop PC
How can i set up the microphone on my acer ( aspire 3680 )
Go to Start - Control Panel - Sound - Recording - Recording and you will see a list of connected devices. Check that the Microphone is live and has a green tick and also that the driver name is present. Double click or Right Click the Microphone for setup options. If it is not working you may have to reinstall the sound driver.
If this is not working then check Start - Control Panel - Device Manager - Sound, Video and Game Controllers to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
Also check Start - Control Panel - Device Manager - System Devices to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
If there are no errors then you should be able to use the microphone successfully.
The volume may be muted. In Windows, look at the volume control icon on the taskbar. If it is crossed-out, click on the icon and deselect the Mute option.
• The volume level may be too low. In Windows, click on the volume control icon on the taskbar, and then use the slider control to increase the volume level.
• If headphones are connected to the headphone jack on the computer, your computer's built-in speakers will be turned off.
Oct 02, 2009 | Acer Aspire 3680 Laptop
Yamaha yst ms35d speakers problem/Vista...volume surges to 100%
U may try to check(if u have) multymedia keyboard! i have same problem and the botton for + volume was stuck ! i just pull it back and everything was OK!
Aug 27, 2009 | Yamaha YST-MS35D Computer Speakers
Sound won't work without the earphones being plugged in
Make sure the speaker volume is turned up and also go into Control Panel, Sounds and make sure nothing is muted and all volumes are turned up. Also make sure the speakers are plugged into the sound jack in the back of the pc. The speakers also need power but since the light is on, it sounds like they are plugged in.
Apr 14, 2009 | E-Machines eMachines Desktop PC
There is no sound on my computer
1. Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.‌ If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Right-click the name of the sound card, and then click Properties.
1. Open Volume Control by clicking the Start button , clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
NoteSome mobile PCs have an external volume control on the outside of the case. If you're using a mobile PC, check the external volume control. • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
thank you
Dec 23, 2008 | E-Machines eMachines Desktop PC
Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
Computers & Internet Logo
272 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
