Question about HP DeskJet 3520 InkJet Printer
It says it's "out of
  • HP Master
  • 17,130 Answers
Possible that the in-detect switch/optocoupler detect is sensing a fault.
Check on the paper feed section for the in-detect sensor and make sure that it is reading into the paper. If there is no issue in this section the voltage change on the sensor must be checked with a multimeter as the paper is inserted.
if absent replace the sensor or otherwise the fault is in the main board which can be a digital switch failure to the processor..
Posted on Jan 03, 2011
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
1350 "out of paper", but there is paper in the tray.
If the printer is making noice as it is preparing to print but does not take paper, then it has broken gears inside. Disasembly takes a lot of time and the spare part is called "printer mechanics" which is the half of the printer.
Apr 08, 2012 | HP PSC 1350 All-In-One Thermal Printer
I can not print from my lexmark t642 printer. I get this message " Remove paper from Standard paper bin." I do not have any paper in that area.
If there is no paper on paper bin and you are getting error to remove paper from the standard paper bin, please check for paper jam. it possible that paper stuck right on the path on the paper bin.
For further assistance, please contact Lexmark Technical Support.
Sep 12, 2011 | Lexmark T642 Laser Printer
Paper mismatch error reads on the front panel - "paper other than plain paper detected. Change paper and press ok to continue job." I only have plain white regular paper in!
So frustrating. What solved this problem for me was to change the ink quality to "draft" when I wanted to print. Hope it works for you as well.
Jan 12, 2011 | Office Equipment & Supplies
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
HP DeskJet 3520 InkJet Printer Logo
136 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
