Question about Microsoft Xbox 360 Console
My wireless controller/controllers does not connect anymore...i must say though, that they are connecting when i plug them into a wireless convertor designed by microsft for windows OS...so the problem must be console fault...
  • 839 Answers
There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
Click here to download Microsoft xbox360 repair guide
Posted on Jan 03, 2011
I don't know how to connect my wireless ps2 controller from gamestop!
Should have come with a controller and a wireless adapter. The wireless adapter plugs into the PS2 where the controller would go. Probably has a sync button. Press it (the light will flash) and press the corresponding sync button on the controller. When the lights stop flashing on both it should be all set. Tough tell without a model number, though.
May 01, 2011 | Video Game Consoles & Games
My wireless xbox controller will not connect to my xbox. I've done the spiny thing on both the controller and xbox. Doesn't work. I have four controller that don't connect, all wireless. The non-wireless...
This sounds like you have an issue with your Xbox and not the controllers. You should send it back to Microsoft if you can. Try connecting those controllers to somebody else's Xbox first to confirm.
Feb 21, 2011 | Microsoft Xbox 360 Wireless Controller
Get connection to internet
Connections to the internet can be tricky. It depends on how you connect- modem, lan,or wireless. If wireless, is it at home, or at a hot spot. If you are connecting at home, try shutting off your wireless switch on your laptop.(if you can), then shut off (unplug) your router, plug it back in, and then plug in the lan (ethernet) cord, and reboot. It should find your connection. You might also go to control panel, then to internet options, then to connections. See if there are any listings in the box. You might have to change things if there is one that says "use this connection first" or something like that, if you are trying to connect otherwise. Then go to lan settings, and uncheck "automatically detect settings". For a modem you need to make sure the modem is installed in devices (in control panel) and then make sure the software, from your internet provider, which will tell your laptop which number and how to connect, is installed. If you are using a wireless connection, do as instructed above and uncheck "automatically detect settings." and make sure your wireless switch is on. Occasionally there are conflicting connections, or possibly unsecure wireless connections "remembered" in your system that may have changed. Right click on your wireless icon on bottom right, then network and sharing center, then manage connections. You may want to delete the ones you don't recognize, or the ones you don't use anymore, as you can always connect again if you want to. If you are having trouble connecting to a particular connection, remove it from that list and then try connecting again. I know a lot of this sounds difficult, but like I said, connecting to theInternet can be tricky.
Nov 23, 2010 | Sylvania Computers & Internet
My wireless controllers wont connect. The green light doesn't even come on anymore I've tried connecting in every way I just wondering if my wireless sensor is out
Well,Its either you need to sync your controllers OR switch the batteries around.I had a problem like this a few weeks ago.So try my solution or buy new controllers
Mar 20, 2010 | Microsoft Xbox 360 Console
Its a big ben wireless controller with no usb how do i connect it to my ps3
plug the usb thingy in the pc then connect the bigben controller then take out usb thing plug it into ps3 conct the controller and itz done
Jan 18, 2010 | Sony Wireless Controller for PS3
Wireless mouse stopped working
REINSTALLING WINDOW MIGHT HAVE OVERCOME THIS PROBLEM. GO TO CONTROL PANNEL, WIRELESS WIZARD THEN PROCEDD. SET A WIRELESS CONNECTION, SELECT MOUSE THAN PROCEED
Dec 12, 2009 | Computers & Internet
My Wireless controller is not being recognized by my console, when i turn on the controller it blinks repeatedly, what can I do?
Try using the sync button. Push the sync button on the xbox, then on the controller.
If that doesnt work, get a cord and plug it into the console. One it is connected you can unplug it and shouldnt have anymore problems.
Oct 23, 2009 | Microsoft Xbox 360 Wireless Controller
Wireless Connection
1. go to Start->control panel->network connections->wireless connection. 2. There you will find an option of repairing the wireless connection. select it and repair your connection.
Aug 30, 2009 | Acer Aspire 4315 Notebook
I need the instruction manual for PS3 wireless controller
push the select and L3 buttons at the same time after you push the connect button on the little mechanism, it should flash fast then press the home button to register it., make sure you follow the directions exactly. console must be off and the mechanism must be plugged in to port 1, turn on click the connect button then L3 and select at the same time then home button. the thing is garbage though the control are unresponsive. Took forever before i could get it to register.
Mar 22, 2009 | Psyclone PS3 Wireless Controller for...
XBOX 360 WIRELSS CONTROLLERS JUST BLINK WONT CONNECT
Did you try to press the sync button on both the XBOX and the controller? This should make them connect after they take a second to find out that their searching for eachother. If this doesn't work then you should call into Microsoft and talk to them because the sync system might be faulty. Try the controllers on another XBOX before calling just to make sure though.
Dec 30, 2008 | Microsoft Wireless Controller for Xbox 360...
Microsoft Xbox 360 Console Logo
49 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
