Question about Intel D945GCNL Motherboard
My desktop computer is overheating problem on Intel D945GCNL Motherboard and show the thermal monitor in the cpu .how to solved this problem ? plz help me
  • 675 Answers
Seems you may need to provide a bigger heatsink/fan for the processor or maybe able to put a chassis fan inside the case...I have had this happen on a number of systems in the past...Some of which the temp sensor was defective...had a GIGABYTE board do the same thing...What you can try to do is to go to BIOS setup and go to the pc health page( or the page that shows the thermal data). There may be a setting here to enable/disable the temperature alarm/shutdown...I've had to do this on several boards due to temp sensor failure and being skeptical I made sure the cpu did not get too hot by checking with an infrared temp probe...turned out all was OK
Posted on Jan 03, 2011
Intel D945GCNL has no display though ram, hard disk,power supply, processor is fine
Okay.
Provided you have checked out the simple stuff; monitor, AND monitor cable, suggestion would be to install a graphics card, and connect the monitor to it.
You won't have THE drivers for the graphics card installed yet, as you have no display, but you should get a display you can see well enough, to install the drivers.
I do need to ask a few questions before this is done, however.
1) Do you know the Power Supply is good?
Your LED lights may light, fans may spin, and it may sound like the harddrive is spinning, but the Processor may not be on.
Why?
A) IF, all of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
{ The Intel D945GCNL mobo has an LGA 775 processor socket.
Front Side Bus support is 800MegaHertz.
The motherboard chipset is an Intel 945GC (Part number 82945GC)
Can use up to an Intel Core2 Duo processor, with a 800MHz FSB.
These processors can use up to 65 Watts.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
I'll go with the chipset info, and not the stated 1066MHz support,
http://www.overstock.com/Electronics/Intel-Essential-D945GCNL-Desktop-Motherboard-Intel-945GC-Express-Ch-Refurbished/6113423/product.html
Stated facts from Intel,
http://www.intel.com/support/motherboards/desktop/d945gcnl/sb/CS-026727.htm }
2) How do you know the;
A) Processor
B) Harddrive
C) Ram Memory
D) Power Supply
,is fine?
Connected them/it to another working motherboard? Won't work with the harddrive, unless Windows Activation screen comes up, and then the harddrive will be for THAT motherboard, and not the original one.
Post back in a Comment.
Regards,
joecoolvette
May 21, 2012 | Intel D945GCNL Motherboard
Dear sir, Audio drivers are not install my pc
Hi, download your audio drivers from Intel site http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCNL
select your operating system form the box in the left and click drivers on the right box, just below there will be drivers shown for your motherboard.
Mar 07, 2011 | Intel D945GCNL Motherboard
Sister, Son and I all have the same model Sony Desk Top Computer. Model VGC RB57GY. Computers are overheating and showing overheating error and shutting down. Mine now is shutting down after even a...
May I ask what Temperature you are referring to, and where you are looking for the temperature at/in?
In BIOS?
Do you have external software that reads these temps?
Motherboard temperature?
CPU (Processor) temperature?
ATI Radeon X300 graphics card GPU temperature?
(Graphics Processing Unit)
CPU temp:
What Processor is installed, and what is the maximum thermal limit for it?
Intel Pentium D Model 820.
http://ark.intel.com/Product.aspx?id=27512
64.1 degrees Centigrade, or 147.38 degrees Fahrenheit.
Checked the thermal paste to see if it has dried up?
Even if it hasn't, cleaning the bottom of the Heatsink, and the top of the Processor's case, and applying fresh, new, thermal paste is the way to go.
After a certain amount of time, thermal paste loses it's thermal conductive properties.
If it is a thermal pad, remove it, fly it out the window. They're junk.
Use fresh new thermal paste instead.
(Be sure to observe Anti-Static Precautions)
Fans are all working fine.
According to whom?
The tech?
Not doubting your abilities for one second. DO doubt the many 'techs' who profess so.
Computer case open, observe the Processor Fan. Ensure that is is spinning at all times, and not intermittently.
Also ensure that the fan is spinning at the correct RPM's.
(Revolutions Per Minute)
Same with the computer case fan's, Front and Rear.
Computer clean inside?
1) Processor fan?
2) Heatsink?
3) The area of the motherboard you can see with the computer case open?
4) The area Behind the motherboard, that you Cannot readily see, without removing the motherboard?
5) The ATI Radeon X300 graphics card?
6) The Heatsink on the Northbridge chipset?
Check the cable connection of the Processor fan to the motherboard, and the computer case fans, IF, they (Case fans), have three wires, AND are connected to the motherboard.
One wire is for Power
One wire is for Ground
One wire is for a sensor that detects when the fan should speed up.
Processor fan spin freely? Computer case fans? Feel like they/it, may have a bad bearing?
Let's diagnose together, and see if we can solve this.
If all of the above reads like a foreign language to you, I will explain step by step, and guide you.
Aug 16, 2010 | Sony VAIO VGC-RB57GY PC Desktop
Same prob
This problem cannot be solved by anyone but a trained technician.
It will liklely requires one of the following repairs
1) new motherboard
2) new CPU
3) New CPU fan
4) new ATX power supply
This is my honest opinion after 100+ PM repairs personally.
best of luck,
Sagacious1
Aug 07, 2009 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Intel DG965RY CPU Overheating
Check the clamp of the cooling fan. If the clamp is not engaged, heat sink didn't take the heat away from the micro processor causing CPU over heating.
Jul 03, 2009 | Intel DG965RY Motherboard
No display for the Motherboard D945GCNL
how to solve asus motherboard blackout
Mar 22, 2009 | Intel BOXD915PCYL Motherboard
Intel Desktop Board D945GCNL - Motherboard has no Display & Bip
this is not the solution you folks are looking for, so here goes,a motherboard with physical damaged is going to give you more problems and headaches. i know this from experience, even if you find a new bios chip, you may be unhappy, due to the physical damage. how far does the damage go? to the chipset? is it just the bios? i would first try an add on video card, and see if you can at least use it. or just find a new board. i am sorry.
Mar 06, 2009 | Computers & Internet
MY compuer helds after few minutes
the computer is probably old considering the chipset of the M-board. it might be overheating i would recommend cleaning it from any dust filling the cooling devices especially the cpu cooling
Mar 02, 2009 | Intel Desktop Board D845EPI Motherboard
Intel D945GCNL Motherboard Logo
264 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
