Question about Motorola Mobility L6 Cellular Phone
Speaker and mic problem both are nto working - Motorola Mobility L6 Cellular Phone
    President:
  • 782 Answers
Sir please service your cellphone in the motorola service center.they will service the speaker [or] change the new speaker and mic...........
Posted on Jan 03, 2011
Why won't my NMN6191C work with my XTS5000?
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
May 11, 2014 | Motorola Speaker Mic Nmn6191c Ht1000...
NOT RECEVING OR TRANSMITING
Can you see the s-mete if it has one moving up and down on any channel? Do you hear any audio at all? could be a couple of things. Bad mic switch or mic cable, bad antenna or coax, bad audio amp. To check the audio amp plug in a speaker to the PA jack, put the PA switch on PA then press the mic to talk. If it works the audio is fine the mic is good and the mic cable is good. Noiw plug the speaker into the speaker jack, do you hear anything? If not then your antenna or coax has a problem, fix or replace antenna or coax.
Jan 04, 2013 | Radio Communications
Got sticky stuff in mic, cant hear phone ring
you need to disassemble the phone and clean the little hole of the mic
Dec 03, 2011 | Samsung Cell Phones
Headphones are working and mic is not working
The mics are of two types: electrostatic(cheap and modern) and old-stiled "dynamic". Old souncards were automatically switching to the mics type. Modern soundcards have to be switched manually.
In "sound properties" you first must check in that mic is turned on, mic volume in max and in all menues avd buttons find something like "mic amplifier boost"and turn it on. It's only non-standart mic tuning option in standart systems. All other problems in defects. Soundcards can be verifyed by so:
(with maximal speaker and mic volume) many times plug in and plug out any reacheable mics and headphones to the mic connection nest (hole), and listen(or recording) resulting scratches. If scratches or other related sounds are abscend(only noise), soundcard is bad. The mic problem may be in "jack left-right interconnection". This useful thing may hang some improper cards. Also that cards often cannot work with dynamic type. And they very sensitive to a manufacturer, and model of mic.
Problem may be also in configuring multimode speaker nests in 5_1(7.1) cards like REALTEC - the mic nest may be switched to the speaker output mode. Open Realtec's control center(in control panel or quicklaunch icon) and check in mic nest to "mic mode" or switch mode from 5.1 to stereo speakers.
May 17, 2011 | Computers & Internet
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
My speaker stopped working after some time!
may be problem in lose wire connection ,
check that first.
may be there is a problem in mic from where u talk,
open the mic cover smoothly,check all the wires are joint if not join it properlt,
still problem take off ur mic and check with speaker or with other equpiment like ur mobile headset,if mic is ok then put back, if not do *
join wires again properly,next
open joiner where the speaker and mic are joined,may be there are some wire disconnection join it ,if properly joined,
* then there is a problem in mic
replace the mic with same type of mie or u can use the mic of ur mobile head set or find it someware ,
join it ploperly.
it works.
goodluck
email rushi_jky@yahoo.com
Apr 28, 2010 | Cyber Acoustics AC401 Consumer Headset
Only left speaker works mic does not work asus P5S-Mx SE
check if your audio balance is correct and if you have pluged the mic in the motherboard properly<they are genrely color coded>.
Aug 01, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
HP a1030e will not recognize sound device after reinstalling XP Pro
FRONT MIC NOT WORKING BUT BACK MIC IS WORKING
AND FRONT SPEAKER IS WORKING BUT BACK SPEAKER IS NOT WORKING
Jul 01, 2009 | HP (400745-001) Sound Card
Cannot recognize working microphone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Apr 21, 2009 | Computers & Internet
Headset Problem Rosetta Stone
3.Open Sound
Dec 27, 2008 | Rosetta Stone Chinese Mandarin Level I &...
Motorola Mobility L6 Cellular Phone Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
