Question about LG CG300 Cellular Phone
Inserted sd card in phone and it says 'unknown external memory do you want to format. when i say yes it asks for security code....tried 0000 but no success what is code pleas
  • 133 Answers
It is the handset security code
the original code is 0000, 1234, or 12345
good luck!
Posted on Jan 03, 2011
Forgot my memory card pasword
To format your SD card you need the following SD card, SD memory card adapter, SD card reader on your P.C. first insert the memory card into card adapter, insert the adapter into the P.C, click start>my computer> Secure Digital (SD) card and then navigate into the folder named system folder, open the sub-folder MMCstore and you should be able to see your password and recover it, If you want to reset your password you should just format SD card by clicking start> right click on my computer and select manage> Disk management > go to your SD card, right click on it and select format and then start format.
Jan 10, 2013 | SanDisk 4GB microSDHC Memory Card
What's the security code of my SD?
Hi Karla! What kind of cellphone do you have? It's most likely asking for your phone's security code and not your microSD. If it's a Nokia phone, 12345 should work. You could also try 00000 or 0000. If that doesn't work, just post the make and model and we'll figure it out.
Jan 10, 2012 | SanDisk 8GB microSD High Capacity...
Trying to format microsd to my lg9oo and it wont work asks for a code or freezes up on me. what do i do?
Hey
These steps should do the tick!
1. From the home screen press Menu then select Settings.
2. Choose Memory manager and select External memory.
3. Press Format and enter the password, which is set to 0000 as default. Your memory card will be formatted and ready to use.
4. To view the new formatted folders on your GW300 press Menu and select My stuff. Choose My memory card.
Cheers
May 21, 2011 | Kingston MicroSDHC 4GB (4 Gigabyte) Card...
I cant reformat my phone memory in my motorola w388, i try to follow the steps to master clear but it still unable to work. is there something i can use to reformat my phone memory??its getting worst
hi!
All you have to do to reformat the memory card is that you have to
insert the memory card, press the Center Select Key,scroll to and select Phone Status, scroll to and select Device Info, scroll to and select Storage Devices,select Memory Card and press Options, and then select Format.When prompted, press Yes to continue or No to cancel formatting.
Another step for you to be able to reformat your memory card is you just have to
press Main Menu,scroll to and Select Settings,scroll to and Select Storage Device,scroll to and Select Memory Card,scroll to and Select Format Memory Card, and then
highlight Yes and press the Center Select Key.
And this will also be an option for you to format your memory card.Here are the steps:
Insert the microSD card.
Press Menu > Settings > Security.
Enter your lock code.
Select Format External Memory. (A warning will be displayed.).
If you are sure you wish to remove all the files from your microSD card, select Yes (left softkey).
Thanks!
Apr 17, 2011 | Motorola Mobility W388 Cell Phone
I need to format the memory stick for my cell phone sony Ericsson
For your to format the memory stick of your sonyericsson handset, all you need to do is...
From homescreen, press menu>ORGANIZER>FILEMANAGER>press OPTIONS>SELECT MEMORY STATUS>SELECT MEMORY CARD>PRESS OPTIONS> now SELECT FORMAT MEMORY CARD and PRESS YES.. it will ask for a PHONE LOCK CODE, by default "0000" is the code for SONYERICSSON HANDSET.
OR, once you inserted the A NEW MEMORY STICK, it will immediately format it.
DON'T FORGET TO CLICK ON 4 THUMBS UP! Thanks!
Apr 11, 2011 | Cell Phones
External memory card for LG kc550 won't work
I was also getting bad format error on my LG kc550. Did a little research (read the instruction book) and if you want to properly format your card to work with the phone you must insert the card into the phone then connect the phone to your computer via the USB cable supplied. Go to "My Computer" and you should see that the phone and memory card are displayed as two separate external devices, when you try to access the memory card your computer should ask you to format it. Click Ok and a Format box will come up, click Ok again and your computer will format the memory card acordingly.
Unfortunatly this resulted in my losing 4gb of space on the card, i dont know wether its based on percentage or a fixed amount the phone needs but if thats the case you will need more than 4GB for your card to be formated for your phone
Mar 31, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Lg shine - cannot access micro SD card which i have inserted.
I just got a new LG shine CU720 to format the card you go to settings, reset settings, master clear, memory card, my security code was 0000. Hope this helps someone else looking.
Dec 26, 2007 | LG Shine KE970 Cellular Phone
External memory
hi had same problem,the phone will only work with 1 gb memory card, put 1 gb card in and phone see's it straight away and works just fine
Nov 05, 2007 | LG KG800 Cellular Phone
LG CG300 Cellular Phone Logo
410 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
