Question about Fujitsu Siemens Celsius R610 PC Desktop
Bypassing password I already removed the CMOS battery but ther is no change please help me.
After removing CMOS battery,power up the system and wait until the POST(power on self test ends) no password prompt should appear.Turn system off and replace CMOS battery.
Posted on Oct 06, 2008
After you've taken the CMOS battery out power up and wait until the POST (power on self test) ends.No password prompt should appear.Turn system off and replace CMOS battery.
Short out the jumper pins labeled CMOS
Posted on Jul 12, 2008
Hi i am an indian.sir my laptop toshiba model:satellite A130/A135 Series is asking for bios password.ples help me.
Hi.
If you dont remember the BIOS password, you may remove it by resetting the BIOS password.
Please follow the below steps to reset the BIOS password:
1) Please remove the bottom casing of the Notebook.
2) Once you have removed the below casing, you should be able to see a CMOS Battery.
3) The CMOS Battery will be of a size of a coin.
4) Once you have found the CMOS Battery, please remove and re-insert it again.
5) The CMOS Battery will have the information about the Computer Date, time, BIOS Password etc.,
6) Removing and re-inserting the CMOS Battery will reset these settings, which will also remove the BIOS password.
Please perform the above steps and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 02, 2010 | Toshiba Computers & Internet
How to remove acertravel mate 252 bois password? i enter 3 times wrong password and i recive system disable code 12717
Hi saeedbjaan.
You may reset the BIOS password by removing and re-inserting the CMOS Battery.
The CMOS Battery will store the Computer date, time, BIOS password etc.,
Hence, removing and re-inserting the CMOS Battery will reset the BIOS password.
However, please let me know if you need detailed information to remove the CMOS Battery.
Hope this helps.
Sep 23, 2010 | Acer TravelMate 252LMi Notebook
Im tryng to bypass the password set in the bios i already removed the cmos battery to no avail please help-
Hi And Welcome to FixYa,
When you remove the cmos battery there is a positive and negative side all you have to do is to used the negative side put it back. Then then after that take out the battery to the holder and then place the positive again restart the computer and check your cmos again.
Jan 12, 2010 | Dell Inspiron 2200 Notebook
Can't change enter BIOS on Ubisurfer... help?
Before attempting to bypass the BIOS password on a computer, please take a minute to contact the hardware manufacturer support staff directly and ask for their recommended methods of bypassing the BIOS security. In the event the manufacturer cannot (or will not) help you, there are a number of methods that can be used to bypass or reset the BIOS password yourself.
Try this first :
manufacturer name : HP
password : HP
Method 1 : Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all.For eg: IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set.
Method 2 : Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Method 3 :
Jumping the Solder Beads on the CMOS
It is also possible to reset the CMOS by connecting or "jumping" specific solder beads on the chipset. There are too many chipsets to do a breakdown of which points to jump on individual chipsets, and the location of these solder beads can vary by manufacturer, so please check your computer and motherboard documentation for details. This technique is not recommended for the inexperienced and should be only be used as a "last ditch" effort.
Method 4 :
Password cracking software
The following software can be used to either crack or reset the BIOS on many chipsets. If your PC is locked with a BIOS administrator password that will not allow access to the floppy drive, these utilities may not work. Also, since these utilities do not come from the manufacturer, use them cautiously and at your own risk.
Cmos password recovery tools 3.1
!BIOS
RemPass
KILLCMOS
Dec 28, 2009 | HEWLETT-PACKARD HEWLETT PACKARD PCDO...
I turned on my toshiba l305s-5900d on day and it is asking for a bios password, but i never put on on it. does anyone have any help. i would apprediate any help. thanks john
Try this first :
manufacturer name : Toshiba
password : Toshiba
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
Method 3 :
Method 4 :
!BIOS
RemPass
KILLCMOS
Dec 10, 2009 | Toshiba Satellite Pro L300 Notebook
Bios password cant boot password protected
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 09, 2009 | Dell Latitude D505 Notebook
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
Cannot Remember Password
Remove the cmos battery from the motherboard for about 5 seconds, replace & reboot. Hope this helps & please remember to rate my answer. Thanks.
Jan 08, 2009 | E-Machines eMachines Desktop PC
HP NC6120 NOTEBOOK
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=447346&swItem=PSG_I23875-109136&prodNameId=447347&swEnvOID=1093&swLang=8&taskId=135&mode=4&idx=1
Here is a link to download a file to flash your BIOS that will make the password go away.
You will need an external USB Floppy Drive since im assuming you cannot get into windows from your laptop.
Jul 14, 2008 | 3dfx Voodoo2 1000 (12 MB) Graphic Card
BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
May 03, 2008 | Toshiba Satellite A105 Notebook
Fujitsu Siemens Celsius R610 PC Desktop Logo
706 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
