Miele Washing Machine Carbon Brush Kit WM81664
SOURCE: samsung washing machine carbon brushes (b1215j)
yes i have this carbon brush
how can i send u this carbon brushes .
where u live and from?
my e-mail address is
identity_ahsan@yahoo.com
Posted on Jan 30, 2008
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
Where we buy Samsung Washing Machine replacement part i need a (motor carbon brush) Model for WF-B1061
samsung authorized repair shop spares
go google to samsung spares direct
find an appliance repair shop as the motor may be generic or have generic brushes fitted
Sep 30, 2015 | Samsung Washing Machines
Miele w911 washing machine Main Wash light flashing. Replaced carbon brushes. Machine needs kick start or ???
carbon brushes r black as, well, carbon. They need replacing when they r worn not blackened.
try something else
Feb 18, 2015 | Miele Washing Machines
How to locate the washing machine brushes?
Some motors do not have carbon Brushes as its a induction motor as a opposed to a reaction motor which does have, not sure about your model but you could check this first, if it does have a brush kit fitted they should be easy to identify and remove if on the other hand no brushes then you would need to fit a new motor. On the bosch the brushes can be hidden look at the back of the motor ,you will see two wires one for each brush connected. Good luck.
Jun 03, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
Rinse light flashing
There are two main causes for this failure:
- carbon brushes are worn
- electronic is defective
The exact solution is depending on the model of your Miele washing machine and works for all modules that start with:
EDRU, EDSU, EDSTU, EL, ELP, EDPL,
you may visit youfixit.eu for a solution.
Miele repair Address and payment information
Feb 09, 2014 | Miele Washing Machines
Will not spin
Possibly a Carbon Brush replacement on the main Motor..worth checking this option before proceeding.
Jan 25, 2014 | Miele Novotronic W1918A Front Load Washer
How do I fix a F53 fault ona Miele W1712 Washing Machine
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
May 01, 2011 | Miele W1926A Front Load Washer
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Jun 15, 2010 | Miele 300 Front Load Washer
My Maytag Neptune washing machine won't spin in the spin cycle
it may be the carbon brushes on the motor worn down, may need to replace, ideally the black carbon brush needs to more than 10mm if less the brush are struggling to have contact with the armature of the motor
Apr 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
