Question about Alesis Multimix 8 USB 2.0 8-channel Mixer
Where can i get an alesis multimix 8 usb 2.0 220V power supply?
  • Alesis Master
  • 5,603 Answers
Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
Also check for "polarity" (which part of your plug is + or - ).
Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
Midiman multimixer
If there's no polarity indicated on the connector on the unit, it's likely an AC supply. Many of these units use a 9V AC supply.
Jul 17, 2012 | M-Audio MIDIMAN MultiMixer 10 10-Channel...
Wanted the instructions to assemble a set of ElectricDrums,/DM5,ALESIS
Which is it... a DM5 set or an SR16? This Fixya thing is disgusting trying to offer up brands and models.
IF you might have an SR16 that has a problem, the USUAL problem is using the WRONG power supply with it. You CANNOT use universal power supply... you must use the official adapter or it will not work.
Nov 01, 2011 | Alesis Sr 16 Stereo Drum Machine
My quadraverb has no effects information on the screen, but all the effects work well .can someone tell me why thanks jon.
there may be maybe 2 a causes like it has a cut board or just the 7 segment fails!and need to replace a new one 7 segment
Jul 16, 2011 | Alesis Multimix 8 USB Powered With Effects...
I AM LOOKING FOR A N ALESIS 8 CHANEL MULTIMIXER THAN CAN BE USED WITH 220V
Since this unit uses so little power, I would recommend a small stepdown transformer. A 20 or more Watt one is sufficient. DO NOT use a convertor that is intended for appliances like hair driers.
Here is a link... the smallest would work and costs $8... I don't know how they can make them for that. You might consider getting a bigger one if you get other equipment to run as well.
Finding the special power adapter that uses 220 and is compatible to the Alesis would cost much more.
Mar 14, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
I record a podcast with the 8track multimix usb Alesis. I use one XLR - Jack input and the rest XLR-XLR. There are 4 inputs being used in total. I seem to be getting alot of hiss and buzzing from the...
What is the source of the input signals? These need to be balanced lines and the sources need to be balanced. If you happen to be using condenser mics, you probably haven't turned on the Phantom Power in the mixer. If you are recording from a sound card in the PC, those have a lot of noise and are unbalanced and you have to use DI's with ground lift ahead of this mixer.
Feb 08, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
The peak light stays on and sound quality is gone to poo :)
You have to reduce the gain control for the input that clips (keeps the red peak iluminated). I suppose that the audio device that you connect at this input is connected at the line input (6,3mm jack) if it's a line level one, or at mic input (XLR 3 pin connector) if it's a microphone level one. You can clarify the gain controls from this picture:
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 01, 2011 | Alesis Multimix 16 USB 2.0 - Mixer With...
Alesis Multimix 8 USB 2.0 8-channel Mixer Logo
315 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
