Question about Dishwashers
I have a hoover HED6612-80 dishwasher two years old. It starts its program o.k.then it gets stuck after pre-wash sometimes it goes to wash but not rinse Sometimes it works fine , today it stuck on dry. please help.
Richie_asg1
  • 1036 Answers
SOURCE: Not going to dry
You seem to be looking at the right things.
PDF of manual - Last page gives error of 3 lighrs meaning temperature sensor fault or element fault.
There are usually 2 temperature sensors fitted. One is "running" and the other a safety cut out.
Check both are ok and closed when cool.
It is possible the element is faulty - causing too much current draw - which is sensed and prevents use.
I would replace the element if it is older than 3 years, as the temperature sensors are usually all or nothing devices.
Posted on Sep 22, 2009
Testimonial: "1st time of using and great feedback given"
SOURCE: My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Posted on Nov 25, 2006
  • 10865 Answers
SOURCE: hi, hoover hed6612-80 when the door is opened the
The problem is most likely that the drain is blocked. Remove the lower front panel on the dishwasher. You will see the drain hose connected to a small pump close to the floor. disconnect the hose and remove the pump. There will be some water so be prepared with some paper towels, or rags. Remove the small pump so you can visually inspect it on the inside, remove any debris you find. If there is no debris there go under the kitchen sink and disconnect the other end of the dishwasher hose. you can then remove the entire hose to inspect it for a blockage. If no blockage in the hose, you must then check the path of the drain water through the garbage disposal [if you have one] and then the trap.
Posted on Oct 01, 2009
  • 5 Answers
SOURCE: Hoover hed6612 dishwasher wont work
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Posted on Mar 30, 2010
  • 5 Answers
SOURCE: have a hoover hed6612 dishwasher just over a year
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
Hoover washing machine gets stuck between program 9-10
You have a fault inside your timer, These can be repaired but due to the age of the machine it may or may not be worth while repairing, The machine is sticking due to a contact issue somewhere inside the timer.
Mar 08, 2012 | Washing Machines
What tray is what for a Hoover nextra washing machine?
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Methinks you could also do with a manual!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 22, 2011 | Hoover Washing Machines
My dishwasher get stuck after the pre rinse with both lights ,the pre rinse and wash lights flashing,failing to go to the wash programe.
It is likely the drain pump or hose is blocked.
It might be helpful if you can provide the full model number of the candy dishwasher.
Dec 12, 2010 | Candy Dishwashers
I have a hoover dishwasher and it starts pre wash cycle then wash light comes on and it beeps and stops
THE PROBLEM IS THE LITRE-COUNTER SWITCH AND IF YOU CUT THE PLUG OFF, SOLDER THE WIRES AND SEAL, IT WILL WORK AGAIN NO PROBLEM, ITS COTACTS THAT GET MOISTURE ON THEM. EVERYBODY THINKS ITS PCB OR PRESSURE SW BUT ITS DEFO NOT. I KNOW BECAUSE I WAS A HOOVER ENGINEER.
May 23, 2010 | Dishwashers
Hi, we have a Hoover HEDS668-80 dishwasher at work. The first problem we had was none of the programs would run this turned out to be a broken door lock. After replacement we managed to get one pre wash...
Hello... Did you check the water inlet pump is turning on to let water go inside the machine? I think if you starts a cycle and feels no water in machine it stops and give error... Hope that will be faulty or before that I'm pretty sure you forgot to open the water inlet valve because you recently repair ?? please check
Sep 21, 2017 | LG LDF6810 Built-in Dishwasher
Have a hoover hed6612 dishwasher just over a year old, it pre rinses and part washes and then doesnt move to the next rinse cycle instead it stops and beeps continuously with the prerinse and wash buttons...
Dec 06, 2009 | Hoover Dishwashers
My whirlpool ADG 7540/1 doesn't heat up properly when washing, sometimes "lukewarm", sometimes a bit warmer still but not the 65 c of the programmed wash. Any ideas?
I have a Whirpool ADG7540/1 integrated dishwasher that goes straight to rinse programme, it is 6 years old, has it come to the end of its day or is there someone out there that can help? Sheelagh Fed up (Pontypridd)
Apr 21, 2008 | Whirlpool Dishwashers
Dishwashers Logo
101 people viewed this question
Top Dishwashers Experts
Owen Barnes
