Question about Dryers
Maytag Neptune Dryer - water in the door jamb
When we dry clothes or towels water builds up in the door jamb and the clothes have difficulty drying. Lint trap is clean and there are no kinks in the outlet hose. Any idea why the water (condensation) is accumulating in the door space>
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
MY Solution:
You have a definite air flow obstruction. To prove this, temporarily disconnect the vent tube from your dryer and run a normal load of clothes through a cycle.( You can place an old nylon stocking over your dryer vent outlet temporarily). If it dries normally then you will need to investigate your venting situation a little further. You don't describe any abnormal sounds, but a faulty blower in the dryer could also cause low/no air flow, so if you do not acheive any favorable results after the vent test, look at the blower next.
Side Note: If you use fabric sheets in the dryer, an invisible sheen can coat the lint filter, slowing airflow. To test this, run your filter under running water,(horizontally), and if it retains the water, replace the filter and avoid using fabric sheets.
Below is a link that will help assist you in disassembly and part description diagrams:
http://www.repairclinic.com/0100_18.asp
Follow this link if you need a new blower:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516674&PPStack=1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
Currently the dryer is not drying clothes at a great rate of speed. The heat is on but it is not enough to dry the clothes in a timely manner. Please help me with a solution, I really enjoy the Maytag...
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 08, 2011 | Maytag Neptune MCG8000AW Gas Dryer
My dryer takes too long to dry clothes. It could take up to 4 hours to dry a load of towels on high setting. What could be the problem?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Oct 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
May 28, 2009 | Maytag Neptune Washer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I have a maytag intellidry dryer and when finished with drying, clothes or whatever are still damp
Check the ventilation for lint. You may need to replace the duct vents if you have any. The lint tends to build up and prevent the dryer igniter from staying on thus the clothes do not dry all the way.
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
99 minutes
It sounds like you may need a new timer. Has water or anything gotten into the timer. This could be causing a short or faulty reading in it.
Dec 20, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
66 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
