Question about Whirlpool Washing Machines
Keep getting f11 error on
Keep getting f-11 error on my whirrpool washing machine
  • 5,911 Answers
Click on the following link for an explanation of the "F11" error code:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
If you require additional assistance, please let me know. I hope this helps you.
Posted on Jul 09, 2008
Keep getting F 11 flashing and machine does not continue to wash
'F11' for Whirlpool decodes as 'communications error' which sounds major BUT is not uncommon in these machines and is often caused by poor contact between plugs/ cables and the control PC, just needing re-seating- by an engineer with a bit of luck ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 01, 2011 | Kenmore Elite 45986 Front Load Washer
What does f 11 indicate. The wash gets to the end of the cycle but F11 then appears and the door will not open.
F11 - Pump cannot be activated
f11 lights 1&3&4, pump/draining error
this means an open circuit pump or fauty pcb
Nov 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Hi I have a hotpoint ultima it is showing f11 could you tell me what it means Thanks
F11 - No pump connection.The drain pump is either blocked or drain pump is loose or drain pump hoses are loose .Or the drain pump connections are faulty. The error f-11 is related to drain pump and its connections,. ----------- You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
I keep getting an f 11 error code? what seems to
F11 is the code for a communication error between the CCU and motor control unit.  sometimes just re-seating the connectors on the CCU cures it.  if not, odds are it is a faulty CCU and needs to be replaced.
Jul 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The machine stops
The F11 error code is a communication failure between the 2 control boards. This includes both boards & the wiring harness as potential defective components. However, this is usually the main machine control board that needs replaced.
Dec 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Erroe f11
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the pre-wash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service technician.
Sep 01, 2009 | Kenmore Washing Machines
My washing machine keeps flashing F 11.
F11 means Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Solutions:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
May 18, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Error Code F11
its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool Duet Washer
Jake at applianceblog says that the F11 is a "Serial Communication Error"
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
If all the connections look fine , then its possible the CCU is reading wrong and will need to be changed.
Nov 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
169 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
