Question about Whirlpool Dryers
I had no problem with my dryer until...We vacuumed out our dryer, including the exhaust hose. The dryer doesn't dry clothes. The automatic dry will run until its manually shut off. The Timer still works but the dryer never gets warm. What happened?
  • 190 Answers
Dear customer,
I recommend you to kindly follow the rouitne below before taking it to your dealer..
hope u find this useful. thank you.
Posted on Jul 09, 2008
  • Ajith Kumar Jul 10, 2008
    Please Rate the Solution.. Thank You..
My dryer is smoking and making a noise
This is not good and should be disconnected from power source until problem resolved. It sounds like an accumulation of lint in the dryer base, where motor / belt compartment are located. Vacuuming all the lint from inside the cabinet will reduce the risk of a lint fire. Cleaning the exhaust / vent hose all the way through to the outside of building will allow better air flow. I have used a leaf blower to do this. Disconnect the dryer hose from the back of the dryer, and insert the leaf blower nozzle. Secure hose to leaf blower nozzle as best you can so it is air tight. Switch on the leaf blower for half a minute or so. Any accumulated lint in the dryer vent line will be discharged to the outside of building. Reconnect dryer hose to dryer and test to see if clothes are now drying faster.
Jan 07, 2014 | Frigidaire GLER341A Electric Dryer
I have a KitchenAid clothes dryer and the drying cycle will not cut off automatically, i have to stop the dryer manually. What is the problem?
you have a bad exhaust sensor on the unit, when the clothes are dry and the temperature raises hotter and hotter, the sensor realizes the clothes are dry and breaks the circuit, the sensor is located on the exhaust tube. the exhaust tube is what the hose attaches to to vent the air outside, take the exhaust tube off, then the back of your dryer and look to see where the tube is that vents from the dryer to the back where the attachment was, there should be a sensor there with two wires, you can test it for continuity but it will probably be stuck closed so you will get continuity no mater how hot it gets, just replace it with a new on... its probably 25 bucks
Jan 01, 2013 | Dryers
I have an older model gas dryer with the lent catcher located on top of the dryer. It spins and it gets hot but it is not drying properly. I have to run the dryer three times to completely dry my...
you might have a restriction in the exhaust system. check the entire exhaust vent tube/hose from the back of the dryer to the outside of the building for any restrictions. check the outside exhaust vent for any restrictions or obstructions. make shure the exhaust tube/hose are as short and straight as possible any sharp curves or bends can restrict air flow.
Oct 07, 2011 | Whirlpool GGW9868K Gas Dryer
I have a Magtag Neptune dryer that recently began taking a long time to dry the clothes. I noticed that the exhaust hose was not very secure at the dryer and there was a lot of excess lint could that cause...
a vent hose that is full of lint or clogged/restricted will cause the dry to take longer to dry or leave the clothes damp. if you clean/get the hose unrestricted this should rectify the problem. Hope this helped tim
Sep 01, 2010 | Maytag Dryers
I have to run the dryer cycle three times before the clothes are dry.
Your exhaust is probably clogged. Your macnine must be able to breathe.
Pull your machine away from the wall and check that hose all the way to the outside. Check that outside vent device as well, make sure it will open and close as is necessary. While you have it open, run a vacuum hose into the dryer to assure no clogging internally.
If you can do it, I suggest you replace your plastic hose with a aluminized hose available at ACE and other good hardware stores.
Thanks for your interest in FixYa.com
Feb 05, 2010 | Whirlpool GGW9250PL Gas Dryer
Whirlpool duet GGW9250PW2 not drying effectively. We run on more dry setting.
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Dec 22, 2009 | Dryers
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Takes a long time to dry clothes
You might want to clean out the exhaust hose where it goes thru the house. Also vacuum inside the unit to if you havent done so already. Let me know if this helped
Apr 27, 2009 | Dryers
Dryer not completely drying clothes.
Cleaning the lint trap of the dryer may is not enough in some cases. I suspect you may have a problem with the vent ducting that extends from the the exhaust of the dryer to where it exits your home. The majority of dryer heat realted problems are due to poor ventilation and clogged vents. I dryer left in this condition will overheat to the point of failure. Not to mention, this creates a fire hazard and a habitat for rodents.
A simple test to determine if you have a dryer ventilation problems is to remove the vent hose from the back of the dryer and attempt to dry a load WITHOUT the vent hose attached. The air exiting the back of the dryer should be warm and forceful. If the clothes dry normally, then you need to inspect your vent ducting from where it enters the wall, to where it exits the home.
If the air flow is weak and your clothes still take a long time to dry, then you need to inspect the INTERIOR ducting of the dryer. Namely, the air blower housing. I suspect you'll find your clothes will dry better with the vent hose removed. Since it dried normally BEFORE you moved, and now it doesn't, you need to take a serious look at where the vent exhausts to. If the ducting runs through and attic or crawl splace they typically development sags, kinks and can clog. The rule of thumb when it comes to ducting: the SHORTER and STRAIGHTER, the better. Every bend you put into a dryer vent creates resistance to air flow, makes the dryer blower fan work harder and creates choke points where lint can accumulate and clog. Perform this simple prelimnary check and let me know what you find. I hope you find this advice helpful.
PS Do not run your dryer for extended periods of time without the exhaust hose attached. This will add humidity to your home and potential mildew. One load should be enough to determine if you have a problem. Don't run it this way as a normal everyday routine.
Sep 08, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
Dryers Logo
88 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
