Question about Acer NSK8458AN Keyboard
My elderly father in law can't get any sound, are there mute and volume buttons on the keyboard? Many thanks
My Panasonic cf-w8 is mute? How do I unmute it? Does the Fn button have something to do with it?
Well the FN key could have set the mute on if the mute key was also pressed.
Click the megaphone at the bottom right near the time and open the audio properties and volume control. Check to make sure the mute is not checked.
You can also click Start/Control Panel and look for Audio or Sound and adjust to make sure the mute is not check.
On your keyboard if you Press and Hold the FN function key at the lower left portion of the keyboard then you can hit the key that has the megaphone with an X across it to take the mute off.
Some laptops have 3 buttons that control the volume. One for turning the volume up, one for turning the volume down and one for muting the volume.
May 02, 2012 | Panasonic Toughbook W8 Rugged Notebook -...
Pc sound is not working right now hepl me
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Computers & Internet
I pressed the volume control buttons @ top of my keyboard, specifically the volume 'off' button; how do I regain my volume control?
Kindly let us know more details like the operating system of the computer (Windows XP,Vista) and also the model number of the keyboard.
Generally, the Volume Off or Mute feature can be deactivated by pressing the same button, i.e; the Volume Off button.
Alternately, you can Unmute the volume by clicking the Speaker (volume) icon in the taskbar (lower-right corner of the desktop.) and unchecking the box next to Mute. (See attached image)
Hope this solves your problem. For more help and clarifications, please feel free to reply to this post with the details.
Thanks for using FixYa.
Dec 21, 2010 | Computers & Internet
Something happened to the volume on my pc.....if I hi the mute button on my keyboard....how do I unmute? I've pressed the volumne button......I've done everything tech sayes to do re volume, sound ...
Click on the desktop tray icon sound button, and uncheck the mute button. If the icon is not visible just see by pressing the left arrow button if icon is present and remove the tick mark on the mute.
Sep 05, 2010 | HP Computers & Internet
Sound wont go on. muted but i have no way of unchecking the mute box
Go to the top of your keyboard. There is a button with a black sideways bell shape icon on it ( a speaker) (the f3 key)...probably four in from the left starting with esc. Toggle that on. It may be on the mute setting now. It should have waves coming out of it when it is unmuted. To the right of that button (two buttons to the right) is the increase volume control button, the (f5) key. Make sure the volume is up! If it is down all the way you will hear nothing and it will be also muted.
I am not sure why if you go into System Preferences (under the Apple icon) and scroll down to Sound and Output, the mute box cannot be unchecked. Perhaps using the function keys to unmute and increase volume on the top of the keyboard will help.
May 07, 2010 | Apple PowerBook G4 Mac Notebook
No sound (ringer, keyboard, etc.)
You may have hit the mute button, you may have turned the volume down using the buttons or you may have accidentally put it in airplane mode or another mode where "sound off" is specified.
Hit the volume mute button, hit the volume up button, go to settings for the volume option, go to the settings menu and change the mode that the phone is set to a standard mode
Dec 18, 2008 | Cell Phones
Sound but no picture
If "mute" has been selected, the volume will still show on the screen, and will only unmute if the volume +button is pressed or if mute button is pressed again...accordianman
Mar 09, 2008 | Audio Players & Recorders
TV Volume goes up when channel is changed Philips 20S240
I don't think the IR sensor has anything to do with it. It sounds like a surface mount micro processor to me...
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Love my new Saitek Keyboard, but I don't what some of the buttons do???
You can download a manual here: http://www.saitek.com/manuals/eclipse_manual.pdf For the 1, A, and Down Arrow: My guess is that these are actually the indicator lights for Num Lock, Caps Lock, and Scroll Lock. For the four silver round buttons: The top right corner of your Eclipse keyboard features a set of controls for changing your computer?s audio volume and the brightness of the Eclipse Keyboard?s backlighting. To reduce audio volume, press button A until the desired volume level is reached. To increase volume, press button B. To mute the audio output, press button C and press it again to cancel mute. Press button D to control the brightness of the backlighting. Press the button to scroll through lights off, lights full brightness and lights half brightness.
Apr 18, 2007 | Saitek PZ30AU Keyboard
Acer NSK8458AN Keyboard Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
