Erro C-5354 in Konica C250 color - Office Equipment & Supplies
3 Suggested Answers
taminol
  • 62 Answers
SOURCE: Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
Posted on May 27, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: error code 5354 in Konica minolta c252
C5354 code means your Ozone Ventilation Fan Motor has failed to turn or spin up as it should. You will need a service tech to either clean or replace the fan as the machine will not run if this motor is not.
Posted on Jan 12, 2010
Misfeed detected after replacing atdc sensor
For which color did you replace? because you are dealing with a color machine C250 that is part of the image unit so which color??
Jun 24, 2016 | Konica Minolta bizhub C250 All-In-One...
My konica minolta c250 is not ready but displaying warming up for a very long time and it did not ready still yet
Warming up means that the copier is not getting hot enough in fuser section, Secondly during that time certain internal house chores are done by the copier to prepare it for READY TO COPY. Are all the image units and toner cartridge OEM!!!??? second has each image unit and toner properly shaking ensure toner in toner cartridges and developer in the image units is spread evenly across each pull each out. shake side ways to ensure spread evenly, last time toner full was run nd gradation adjustments run ?
Dec 02, 2015 | Konica Minolta Konica Bizhub C250 Color...
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Apr 19, 2015 | Konica Minolta bizhub C250 All-In-One...
Konica C250 has a faded line on the prints. Prints colors well except for the Faded line.
The developer powder needs to be replace. for whatever color that's faded, wont be the drums.
Sep 06, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica C250 color issue
Needs to have a gradation adjustment done through service mode. If that doesn't fix the problem, you will need to replace cyan drum unit.
Feb 16, 2014 | Konica Minolta bizhub Office Equipment &...
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
P-21 and p-5 error message. and fully cyan color comes.
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Nov 27, 2011 | Konica Minolta bizhub C250 All-In-One...
Bizhub c250 minolta all in one no color printing
What driver are you using? The only reason I have seen when these machines do not print in color is if you are using a PCL6 driver which is black and white only. Be sure you are using the PCL5c driver if you want to print in color.
Sep 24, 2010 | Konica Minolta bizhub C250 All-In-One...
Error code C5354 on our Konica Minolta machine
Ozone Ventilation Fan Motor’s failure to turn. To clear open and close the door where you place the toner.
Mar 13, 2010 | Minolta BIZHUBC351 Color Copier
183 people viewed this question
k24674
