The integrated dvd player will not read the dvds, any advice on how to fix this problem, I have already tried a disc cleaner?
  • Televison & ... Master
  • 17,130 Answers
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. Hence the rejection but the best is for cleaning manually the laser head eye with a cotton bud very softly and without pressing the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
Please take an estimate of the cost of the optical head before you can decide to replace.
Posted on Jan 03, 2011
How to fix marantz dv6200 when all CDs give "disk error"?
DVD CD players have two lines of print to read normally the DVD line goes first . You need to have the head cleaned try a disc cleaner if no good get the heads pro cleaned
Sep 01, 2013 | Televison & Video
Problems reading dvds
Have you tried cleaning the lens of the portable player? You can purchase a DVD cleaning disc, this disc has microfiber brushes which clean the laser len assembly of the player as the disc spins.
Hope this helps
Jul 06, 2008 | Televison & Video
My iView 2000hd DVD player does not read any DVDs that I put in it. It scans it for about a minute then comes back saying that there is no disc. It tried a couple DVDs, making sure that it wasn't any...
hi there.
DVD Player Disc Not Reading Repair Tips. DVD players use an intricate laser device to scan the surface of the DVD. ... When a message appears that there is nodisc in the player when there is, it indicates a problem with the disc, the laser, or the loading mechanism.31 Mar 2015
DVD Player Disc Not Reading Repair Tips ' Techwalla.com
https://www.techwalla.com/articles/dvd-player-disc-not-reading-repair-tips
How do you clean a DVD player at home?To maintain your DVD player, occasionally unscrew the player's case, so you can get at the lens to clean it. You need a screwdriver, canned air or a soft brush, a foam swab or camera-lens cleaner, and lens cleaning fluid from a camera store. Here's what to do: Remove the top cover screws.How to Maintain Your DVD Player - dummieswww.dummies.com/home-garden/home.../how-to-maintain-your-dvd-player/Search for: How do you clean a DVD player at home?
Why does a DVD player skip?One of the most common problems that occurs with DVDs and DVD players isskipping. ... The same thing occurs when a DVD skips only it messes up the picture and can cause you to miss whole sections of a movie. An excess of dirt, grime, dust, and even fingerprints can damage discs and contribute to skipping.31 Mar 2015How to Fix a DVD Player That Skips ' Techwalla.comhttps://www.techwalla.com/articles/how-to-fix-a-dvd-player-that-skipsSearch for: Why does a DVD player skip?
if you go to this link it will show what a laser disc cleaner looks like and where to buy one from.
DVD laser disc cleaner Google Search
Nov 21, 2017 | Televison & Video
Lincoln Navigator Dvd player will not read the Dvds
try cleaning the unit with a disc cleaner.and make sure all dvds are clean
Sep 10, 2008 | 2003 Lincoln Navigator
DVD problem
It could be a couple things...
#1. Over time, dust and deposits can accumulate on the laser that reads the disc. In many cases, DVD players with this problem can still read CDs. You could try a DVD laser cleaner, which is usually a disc that has a tiny brush glued onto it. Run the cleaning disc 2 or 3 times, and try it again. Try both CDs and DVDs, since CDs are easier to read than a DVD.
2. After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. In many cases, DVD players with this problem will still be able to read a CD. I'd try a cleaning disc first, since the only way to fix this problem is to bring the unit to a service center for repair.
Let me know what happens after you get the DVD laser cleaner and run it. Hope this helps.
May 07, 2008 | Televison & Video
Dvd player problem
get a dvd cleaner from best buy. mine did the same thing, it would not play any dvds so i resorted to vhs, and once i had watched all of those, i finally got a dvd cleaner and now it works fine
Jan 20, 2008 | GoVideo DV2150 DVD VCR
DVD Player/recorder
yes ,you can try to buy at radioshack a cd cleaner if that does'nt fix the problem you'll need a new optic,let me know
Jun 10, 2007 | GoVideo VR4940 DVD Player/VCR
Dvd always says no disc
i had this problem for copied dvds and cds and badley scratched ones when renting. never had the problem with genuine products. it seems to be able to dectect snide dvds but my 20 quid jobby in the bedroom will play them all !!!!!!
Sep 29, 2006 | Sony DAV-S400 System
Integrated DVD player
If your handy, then try to disassemble the DVD .player from the unit and manualy clean the lens assy,but please be aware of the HI Voltage dangers inside of a tV set. if your not then Please call a pro top assist you with this repair. If the units not worth fixing then simply buy and inexpensive DVD player/recorder and hook it up via the external inputs. Good Luck
Jul 24, 2006 | RCA Scenium D40W20 40" Rear Projection...
DVDs won't play
Hi Pookie, This is an easy fix. All you need to get is a CD/DVD-Player Laser-Lens Cleaner for about $5.00. You can get these at Best Buy, Circuit City, Radio Shack, or any similar place. Use this, and let me know how it works for you. Best regards, nightdiver
May 27, 2006 | Sony DAV-C450 System
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
