I cannot open tray to insert DVD - Televison & Video
  • Televison & ... Master
  • 17,130 Answers
Possible fault in the loading mechanism of the player, it can be failure of the belt or the gears or the loading motor, loading motor drive IC or the trigger from the main control processor.
You might have to check the loading motor voltages from the processor , the main voltages to the drive .Check manually the mechanism to confirm that it moves freely.
Posted on Jan 03, 2011
Open dvd tray
Hi, Usually there is a button on the cover of the DVD door. Also there is a small hole to the right of centre of the DVD door that inserting a straightened out paperclip you can insert and press a release to open the tray.
Dec 25, 2014 | Computers & Internet
Replace cd player
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Apr 16, 2013 | Samsung Computers & Internet
I inserted a DVD wrong side into NEC TV NLT-!9HDDDV3. How do I remove it?
Mar 29, 2013 | Computers & Internet
My dvd will not open
All CD and DVD players have a small hole on the tray. If you insert a paper pin into this hole it will travel free some distance and then encounter resistance. Just press a little more and this will unhook the latch of the tray and the tray will open. You can even try the software method. From My Computer select the DVD drive and right click. One of the options is Eject. Click on it. The tray should open up.
Aug 25, 2010 | HP Pavilion dv6000z Notebook
I am unable to open the dvd tray after inserting a dvd which plays ok.i want to be able to open and close the dvd tray as normal.
There may be a problem with the dvd you are using. If you look at the front of the dvd player there should be a very small hole. Take a paper clip and insert into this hole which should open the dvd drawer.
Now try another dvd to the if the player functions correctly. If not it likely means that there is a problem with your dvd player.
May 20, 2010 | Computers & Internet
SONY RDR-VX500 DVD eject not working
On most DVDs there is a small hole under the tray where you can insert a straightened paperclip, push in and it will manually open the tray. If not if you can try GENTLY prising the tray open by inserting screwdrivers on both sides of the tray with the power off
Oct 04, 2009 | Sony RDR-VX500 DVD Recorder/VCR
DVD/CD tray will not load
With the R800, you must slightly open the paper feed panel door, lift it vertically about an inch and then lay it open horizontally away from the printer. Without doing this, there is no way to insert the disc tray.
Mar 13, 2009 | Epson Stylus Photo R800 InkJet Printer
DVD tray won't open
Look for a small pin hole in the front of the DVD player. Insert a pin into the hole to open the tray.
Also try right clicking the DVD icon, click 'eject', then insert the pin into the hole.
If the door only opens partially, grab it and pull it open. Then insert a blank DVD into the tray, then see if the tray will open automatically with the disk in the tray. If so, then keep a DVD in the tray at all times.
May 27, 2008 | Televison & Video
Digital Apex dvd/cd/mp3 player tray won't open
on the bottom under the dvd tray is a hole. inside the hole is a white plastic gear that opens the dvd tray. it is stamped with a phillips screwdriver depression. insert a phillips screwdriver and rotate to open tray/
Dec 16, 2007 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
