Question about Toshiba e-Studio 350 Copier
The Toshiba e studio355 indictes paper empty although tthere is paper in the drawers. The paper lift motor in both cases are non function. A power failure is indicated along with the paper empty .
2 Suggested Answers
  • 132 Answers
SOURCE: When the paper drawer is fully-loaded and inserted
if you remove the paper tray and you look in the slot that the paper tray slides in you should see a sensor flag hanging down remove the flag, it seems that the sensor is faulty the machine should work but wont let you know when the paper is finished so the very last page will show paper jam
Posted on Mar 19, 2011
My Mita DC 1860 is showing that the lower A4 drawer is out of paper yet the drawer is full. I have on done the drawer and checked for paper fragments after a jam. All has been vacuumed thoroughly. I'm...
On the cassette, there is a floating plastic piece that is on a hinge so it can swing up and down. This arm is supposed to come in contact with the paper as it is raised, and depending on the elevation of the arm, it will display the paper amount. This would be the first suspect for me, I would physically look for this plastic arm and ensure that it is free swinging and does not stick. Also, open and close the drawer and listen closely for the lift motor to activate. If you hear the lift motor, then you most likely have a problem with that plastic piece.
-David.
Nov 04, 2010 | Kyocera Mita Office Equipment & Supplies
F3 ERROR CODES
This code indicates a fault with the paper tray lift-up motor. F3-12 = tray 1, F3-22 = tray 2 etc. To clear this fault switch off at the power supply and empty the indicated tray of all apaper and jams. Operate the lift up section and then close the drawer with NO paper in drawe. Switch on again and after the machine boots up replace the paper in the drawer. This usually works fine unless there is a serious problem with the lift-up motor.
Feb 19, 2010 | Sharp AR-5320 Black and White Copier
Get a load paper in drawer 2 error with the paper in the drawer
Hello sir; Please check the tray paper lifting motor seems it broke, otherwise check the paper sensor .
Aug 05, 2009 | Muratec MFX-2830 Black and White Copier
My toshiba 2060 copier starts knocking when warming up and then show the trays are empty , do you know what it could be?
the lift motor for the paper trays is faulty or if yu pull the trays out and look behind the tray there are som connection there check there aint no paper stuck there.. if you put the trays back in on at a time you should find the one causing the problem.. my money is on the lift motor as this lifts the tray up to the paper sensor to show paper in trays..
Aug 03, 2009 | Toshiba 2060 Copier
Add paper to Toshiba e-Studio 282 Printer
you have a bad lift motor, this motor runs the top two trays (lifts paper to specific height) one or both sides of the motor can go bad (gears break) a good tech can replace in 1/2 hr. when you close the drawers you should hear the lift, if no noise...bad motor
Jul 21, 2009 | Toshiba e-Studio 282 Printer
Paper Error
The paper lift housing is cracked. The clicking noise is made by the lift gears skipping teeth.
It needs to be serviced...in the mean time, you might try feeding 11 x 17 paper through the manual feeder (bypass tray). Or if you need many 11 x 17 copies, it is possible to set another paper drawer to 11 x 17 size...just set the plastic tag in the front of cassette to LD so the machine knows what size of paper to expect (if tag is set incorrectly, machine will jam EVERY TIME)
Jun 10, 2009 | Toshiba E-STUDIO 450 Copier
Brother MFC3360C paper drawer will not open
remove the jam clear cover in the back.
Lift the Pull In Roller
Holder Assembly with a
credit card.
be careful not to lift too much
While lifting the Holder
Assembly, pull the tray
free from the machine
lubricate the right side with a little bit grease where the vshape is located on the tray
Apr 16, 2009 | Brother Multi-Function Center MFC-3360c...
EP3050 error code C0040
A C0040 error code indicates a problem with the suction deck fan. It has nothing to do with the paper lift motors.
The fan is accessed by removing the rear cover of the copier. It is right in the center. These are readily available (p/n 9313-1310-61) although they are not cheap (around $200 retail).
Nov 15, 2008 | Minolta Office Equipment & Supplies
Paper Jam Errors
switch off power to printer and switch on again, worked for me
Jan 14, 2008 | Dell 3100cn Laser Printer
Toshiba e-Studio 350 Copier Logo
164 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
