Question about Dryers
Dryer is spinning but has no heat we have found suggestions on the web to reset the dryer's thermostat by pressing a reset button..... However we are unable to locate this. Any suggestions as to the location of the reset button or further courses of action would be gratefully received. Many thanks
  • Dryers Master
  • 1,525 Answers
Hello. the reset button usually at the back of the machine if there no heat check heat sensors at the back of the dryer with a multimeter there are 2 of them if 1 of is faulty change both of them hope it helps
regards
shaun
Posted on Jan 03, 2011
Hello. My dryer is not heating up. Are there some home troubleshooting things I can do before I call a repairman?
A common problem with your dryer not heating up could be that the thermostat may need a reset. Depending on the model and make of your dryer, the thermostat is normally located inside the rear cover of your driver. You may need to undo a few screws to get to it. Once you have located it, look for a switch/button on the thermostat and press it. This should get your element heating again.
Dec 30, 2010 | Dryers
GE Adora Dryer spins but no heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Aug 05, 2009 | GE WSXH208A Front Load Washer
Maytag dryer stopped heating /drying
ON THE SIDE OF THE BURNER TUBE THERE IS A RESET THERMOSTAT- IN THE CENTRE U PUSH THE BUTTON.
Jul 08, 2009 | Dryers
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
White Knight tumble dryer making a clicking noise when on & has no heat
utube.png You-Tube video "XNxE9eXx2Rk" placeholder (do not delete) utube.png
May 02, 2009 | Dryers
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
WHIRLPOOL DRYER MODEL LEQ8858JQO
Thermostat, High limit and low limit thermostat or even a safety Temp limiter. All three are similar in cost and located on the back inside of the dryer and 1 by the airflow tube under the lint trap.
Apr 08, 2008 | Whirlpool LEQ8858J Dryer
Spare parts
the thermal cutout is the thermostats u have two in a dryer one for the low heat and one for the high heat there just called a thermal cutout switch because it prevents the dryer from over-heating and setting a fire m8 but before you buy one just check if your thermostat for the lower heat might have a small reset button attached to it if it does then press this and if it not faulty will reset itself to start heating up again its that one with the reset buton that are called a thermal cut-out switch let me know which country you live in and i should be able to find you the cheapest web site to order from m8
Aug 20, 2007 | Candy CDC266 Dryer
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
187 people viewed this question
Top Dryers Experts
