Question about Haier hwr10xc6 Air Conditioner
Compressor turns on but unit doesn't cool. - Haier hwr10xc6 Air Conditioner
  • office957 Jul 12, 2008
    Air filter was clean. We're going to exchange the unit.
  • Anonymous Mar 21, 2014
    A/C doesn't cool and compressor does not turn on
    Problem Solver:
  • 15 Answers
Take the air filter out and see if there is a dramatic improvement - if so clean the air fitler - otherwise it may need regassing
Posted on Jul 10, 2008
    Sergeant:
    Champion:
  • 330 Answers
CHECK THE FAN
Posted on Jul 12, 2008
4 Suggested Answers
  • 619 Answers
SOURCE: Hot Compressor, no Cooling
If you have clamp tester / read the label of the compressor how many amphere register give allowance 5 amphere during testing time if register for example 3 to 5 amphere the label is 3 amphere is good the compressor / but it will register 0.5 or 15 amphere or up the compressor is badly replace.
Posted on Jan 08, 2008
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
  • 534 Answers
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Posted on Aug 04, 2009
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
I have a 6 yr old lennox merit 10acc system and the compressor doesn't seem to be running as there is no cold air and line out of compressor is not cold/sweating like my 2nd (good) unit.
you cant check capacitor with power on it nor using volt setting.need micro ferred setting on meter and check with power off and wires removed. leads go as follow for fan one lead on "C" and one on fan. For compressor one lead on Common and one on HERM. Also be sure voltage on capacitor is correct 360V or 440V. 440V will work for either. Also double check micro ferred requierment on motor and compressor. If its been replaced before may have been replaced with incorrect size. It happens.
Aug 23, 2012 | Heating & Cooling
Kenmore 580.15151500 Compressor doesn't turn off
Most likely is a issue with the temperature sensor that when it reaches the level selected is not turning the compressor off.
Jun 15, 2012 | Kenmore Room Air Conditioner
Ive owned the 10x6c for 2 years never used it because of my wiring doesn't have a ground,,let my neighbor borrow it and it doesn't blow cool air I hear the compressor turn on but no cool air?
If the compressor is coming on and the air is not cold, it could be that the freon has leaked out. Easiest way to check for no freon is to take the cover off the unit and run it in cool. The high side which is the smaller line coming into the top of the compressor should be hot, and the low side which is the large line coming off the side of the compressor should be cold when the compressor is running. If there is no temperature difference between the high side and low side tubing, you have no freon. Also check for oil residue once you have the cover off. If you spot oil, you had a leak and have no freon.
Aug 14, 2011 | Haier hwr10xc6 Air Conditioner
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
Hello. I have a Bryant 561CJ030-D AC unit. The fan comes on but doesn't seem to be cooling. We have had record high temps the past couple of weeks (over 100 degrees), and I'm wondering if the...
Is the compressor turning on? The fan may be running, but you will not get cooling effect unless the compressor is circulating refrigerant. It appears your unit is a 2.5 ton unit. What is the square footage of the space being cooled? Is the space insulated?
Aug 04, 2011 | Heating & Cooling
My Amana AAC101SRA doesn't cool like it used to. We have cleaned the filter, but that doesn't seem to help. Should we call a repairman or think about getting another unit?
Is the outdoor coil blocked? Is the outdoor coil clean? Is the compressor running when you start unit. When you turn unit off after running it can you hear a hissing sound from within?
Aug 02, 2011 | Amana High Efficiency AAC101SRA Air...
Sharp AF-M808X air conditioner. suddenly there is only fan air movement. there is no longer any cooling; turning the thermostat knob to a higher level doesn't "kick in" the coolant. but...
Simple test: the thermostat in your unit is electromechanical - unplug the unit from the mains, take it out and measure the resistance between the 2 electrical contacts, if it doesn't goes to near 0 when you turn it even a little bit then it's defective and it will have to be replaced.
If the resistance does indeed goes to near 0 then the defect is in the AC system. Another simple test: open the casing of the unit and put your hand directly on the compressor; now turn the thermostat button. If it doesn't vibrate then the starting capacitor of the compressor has failed and it will have to be replaced with a similar one.If it vibrates then the cooling circuit has got a leak and all the fluid has been lost. For that you will have to call a pro that will solder the leak shut and refill the circuit with the appropriate fluid - only he will have it, it's not sold on the customer market.
Jul 22, 2011 | Sharp AF-M808X Air Conditioner
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
My Vinotemp VT52SN stopped cooling. I was away from home for a few days and when I came back the fan was running and the temp was stuck at 62 degrees. I had it set at 54 (and lower)... the fan runs and I...
How To Test the Compressor Relay The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator the relay is located in the terminal box which is located at the side of the compressor.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
Beneath the terminal cover is found the compressor relay , overload protector and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Jul 08, 2011 | VinoTemp VT-52SN Stainless Steel Wine...
The air does not come on at all but the fan will work.
mcdevito75 Here, You may need a charge of freon, turn the a/c unit off completely and remove plug from wall for about 5 minutes, then plug back into wall, now just put the fan on for 5 minutes, now the cool control, tiur that slowly to it"s coolest point and ss if compressor comes on, if so back off the cool control slowly just until the compressor goes off, if compressor doesn"t come on, contact a local a/c repair shop in your area. They come to the house.
Sep 01, 2010 | Amana Heating & Cooling
Haier hwr10xc6 Air Conditioner Logo
126 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
