Question about NewAir ACS-1200H Split System Air Conditioner
Whmich is the best Split AC that is cost effect and efficient.
  • 2,133 Answers
Any air conditioner with 3 Star ranged. is economical and also efficient.
Posted on Jan 03, 2011
Which are best SIP provider in India?
An SIP trunk provider basically offers services to enterprises to enable a unified international business calling experience. The SIP provider must also prove cost effective adhering to some common features that enterprises require:
A centralized and standardized management of international business calling.
Increased efficiency of data connectivity for the whole enterprise.
Eliminate the strenuous task of dialing multiple numbers, thereby making the corporate calling experience seamless.
Enable the user to automatically share international voice calling capacity all over the organization.
A SIP provider must also benefit the business by streamlining the management, & reduce costs of international communication through premise-hosted PBX or centralized IP-PBX.
You can find the services of Reliance Global Call being the best in India because they offer reduced cost of ownership, flexibility regarding payment convenience, zero rental charges and zero commitment. Their excellent service is also time saving and offers instant provisioning.
Apr 12, 2017 | Best Computers & Internet
Tip
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central air conditioning unit. They also are a very good alternative to window air conditioning units. I will explore the use of these units more closely and look at how they can be used effectively.
One of the many problems encountered by the professional is when they are asked to install central air conditioning in an older home that was never designed with air conditioning as even a possibility. The walls may be very thick stone. Often they have very little or no insulation. The floor structures may be rough cut lumber. The joists spacing may be random. Walls and ceilings are plaster and lathe. Basically everything is stacked against any type of ducted central air conditioning. Many log style homes also are not very easy to get any kind of ducted central air conditioning installed. The open ceilings and the bare log wall design does not allow for any kind of ducting. I'm sure there are other situations. These are the ones that I have come across most frequently.
If you have a home or building that falls into one of these categories you may want to investigate installing a ductless air conditioner. This type of air conditioner can be installed in almost any home or building. The small indoor unit can be attached to the wall with a few screws. Most of the units only require that a three inch hole be bored through the outside wall. In new installations the units can be placed on inside walls with some fore thought and planning. For installation in older homes or homes that are already built you will want to plan the units to be on the outside walls.
The outdoor condenser units can be placed up to one hundred feet away from the indoor units. One outdoor unit can be used for many indoor units. Up to four indoor units can be attached to the same outdoor condenser. Some very advanced electronics will control the operation of the condenser and compressor to supply the refrigerant to the indoor air handler units that are running at the time. With variable speed technology the compressor and the condenser fan will only run as fast as needed. This technology has become very efficient in the last few years. You do not have to give up any efficiency with these ductless split units.
Another advantage to these mini split air conditioners is that they can be controlled to run only in the rooms that you actually need air conditioning in. If you are not going to be in a room you can shut down the unit. The units also have timers that can be set to turn the air conditioning on or off at preset times. If you are not going to be home all day the air conditioning can be setback or turned off. The timer will turn on the air conditioning so that you return to a cool house. Central air conditioning is very hard to zone effectively. Also with large central air conditioning systems the outdoor compressor will be running at full capacity even though only a few rooms amy be calling for cooling. There are some central air conditioning systems that are do some staging and variable speed technology. These are not as efficient or as effective as the ductless split technology.
Ductless split heatpumps are another great idea to look at. For a few dollars more you can also very easily have heat from your air conditioning mini split. Then especially in the mild spring and fall weather you can have some very efficient heat with out starting up that big monster of a furnace or boiler in the basement. In southern climates the heatpump version of the ductless split system may provide enough heat year around.
Ductless split air conditioning is definitely something that can solve many problems for some homeowners. Add to that the many advantages of these units and you will find that they are worth every penny that you will invest into them. As with any project like this make sure that you screen your contractor. These units are not for do it yourself people. There are many things that need to be done correctly for these units to work properly and efficiently. A refrigeration license is also required to install these air conditioners.
By doing a little research and hiring the right person you will enjoy many years of trouble free service from your new ductless mini split system.
on Dec 04, 2009 | Heating & Cooling
Why does it keep stopping with 1st and 7th light on board?
Modern washers have computers. Even worse, some have the computer built onto the main motor. If so, you must replace the entire motor, and no ''DIY''. Best bet... Buy a rebuilt older ''top-loader'' machine with knobs and no lights. (Get a guarantee there is no computer). Almost _all_ modern appliances of _every_ kind all have computers. They are there for ''efficiency'' (i.e. ''cost less to operate''). The ''catch?'' They cost a fortune to repair, and their lifespan is _way_ less than older machines. (It's a _giant_ consumer scam, all in the name of ''energy efficiency''). // My original Central AC lasted 25 years. My new ''efficient'' replacement system lasted one week past the 5 year _limited_ warranty. I'd rather pay higher electric bills than spend $10,000 on a new system every 5 years. // See my point?
Aug 16, 2015 | Washing Machines
I HAVE 1.5 TON SPLIT A/C WHAT SIZE OF RUNNING CAPACITOR WILL WORK IN COMPRESSOR?
the capacitor that is required is the same size as what is fitted
it will read as voltage and uf number
best have a ac technician check it out as it may not be the capacitor but the power board
some ac units have a capacitor that is in effect two capacitors in one to run the compressor and the cooling fan as well
best get the technician in as it could save a lot of money in the long run
Aug 08, 2015 | Dayton Permanent Split Capacitor Motor Fan
WHICH IS BEST A/C NOW
Check out this site. you will get an idea about the types of AC so that you can buy it according to your choice.
http://www.hellogiri.com/home-air-conditioner-split-ac-window-ac-price-details-in-india-best-cost/
thanks for rating Good luck
Jan 12, 2011 | Heating & Cooling
For how long time to keep AC on?
The Department of Energy recommends occupied setpoints of 70degF Heat and 78degF Cool. During unoccupied times, it is recommended to setback Heat to 62degF and setback Cool to 85degF.
If your system is experiencing problems "catching up" from a setback temp setpoint, you will need to adjust these temperature setpoints to allow for your system's capabilities as well as your individual comfort needs.
In short, you will have to find a balance point between your body's comfort and your wallet's comfort.
You also want to make sure you keep your air filter clean. If you have access to your condenser coil (the part outside), wash it down from time to time using a water hose.
I don't know what your location is, but I'm including a link from the state of Michigan which offers some helpful information and advice on how to keep your system running efficiently & effectively.
I hope you found this information helpful. :-)
Mar 08, 2010 | LG Art Cool LA181CNW Split System Air...
Best split ac 1.5 ton
I think you just have a faulty unit. Most of the mid wall split units have similar components and there are only cosmetic differences. Lg is strangely enough a good aircon. Personally i like Samsung .(Spares are easily available). You should concider who the best after sales service supplier is and go that way. (As stated, most units are similar in my oppinion.)
Sep 21, 2009 | LG Heating & Cooling
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
I need help selecting the best Amana 5 ton furnace/ac.
I believe you are asking which furnace to go with?
Just some clarification first.
The "condensor" is the outdoor unit.
A "Compressor" is the device inside the outdoor unit that pumps and "compresses" the refridgerant.
An evaporator is the indoor coil, it has refridgerant running through it.
The furnace is completely seperat from the condensor and evaporator.
I "THINK" you are saying that you are looking to buy an AMANA system with a 5 ton 14 to 16 SEER condensor, and a furnace, but you need suggestions on the furnace.
typically when you purchace a condensor, the evaporator coil is simply matched by the manufacturer to the specific condensor you purchace, there is no choosing to deal with. All condensors ofcourse come with a compressor already installed.
If my assumption about your request is correct, maybe this will help.
Amana's 90+ furnaces are great units. I would recomend them to anyone. The 80+ uses a somewhat inferior heat exchanger, and is ofcourse less efficient.
Anything higher than a 90+ can take quite a while to recoup the costs of the enitial purchace through your efficiency savings.
If it were my home, I would go with the 90+ furnace, and the 16 SEER Condensor/evaporator system. But ultimatly, its up to you, your efficiency standards and your wallets potential.
If you live in a northern state where AC is little needed, I'd go with the 14 SEER AC.
Again, an initial cost verses long term savings issue.
Dec 09, 2008 | Amana Heating & Cooling
NewAir ACS-1200H Split System Air Conditioner Logo
121 people viewed this question
Top NewAir Heating & Cooling Experts
Donni Steen
L Pfaff
L Pfaff
Tom Chichester
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
